Results 1 to 15 of 22
    May 2017
    Pittsburgh
    1993 Rapid Craft Tornado with 2020 Mercury 300R
ID:	490907Click image for larger version.
ID:	490908Click image for larger version.
ID:	490909Click image for larger version.
ID:	490913Click image for larger version.
ID:	490912Click image for larger version.
ID:	490914Click image for larger version.
ID:	490910Click image for larger version.
    $12,000
    The motor that will be included with this boat is a 1990 Johnson 225 hp, not the motor seen in the pics which has sold.
    This hull is nearly identical to the newer Liberator 22' tunnel hull boats sold by Randy Corson new with this exact motor for around 65k.
    The boat shows well for it's age. The gelcoat is in excellent condition. There are some scratches and worn areas on the hull commensurate with a nearly thirty year old speed boat but nothing that compromises the integrity of the boat. There are no stress cracks! It is clear that this boat has been well taken care of. Three bilge pumps all work. Battery replaced early this year. Dual axle trailer is in great shape with tires replaced last year. $1000 custom cover made last year.
    Something to mention for those who've never experienced a tunnel hull boat; they ride incredibly smoothly over rough water.The two tunnels that run under the boat narrow as they run aft which lifts the boat out of the water creating truly air ride suspension!
    Some areas needing attention eventually;
    There was a hot foot pedal with the previous motor setup and four bolts were drilled through the bottom of the boat. It has since been patched but the patch is amateur and so it will need to be redone eventually. It doesn't leak, it just looks subpar. Padding on the front seats is shot and they should be replaced. Rear bench is good. Dual 27 gallon aluminum fuel tanks. Port side tank leaked so I ran it dry. Aluminum tanks are repairable or you could swap it for a new one for a few hundred. There is a toggle switch on the dash to go between the tanks. Speaking of dash, the wiring for the analogue gauges was disconnected when the motor was installed.
    For sale locally. The boat and motor sold as is. I am happy to talk to or message with you if you have any questions.
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    And the price is........
    May 2017
    Pittsburgh
    Quote Originally Posted by TraceF3 View Post
    34500 for the package, sorry I missed that. It's kind of important!
    Jun 2001
    Crosslake, MN
    Anyone know how this differs from the Riot ? Just curious.
    MDS
    Western Pennsylvania
    Quote Originally Posted by mikesufka View Post
    MDS
    Message "Riverratt" it was his boat
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Nov 2019
    Canada
    Would you sell it without the 300r?
    www.InjectorService.com
    Call/Text - 204-326-0390
    Dec 2001
    Sunbury, Pa
    Quote Originally Posted by InjectorService View Post
    Says in the first paragraph $12000 for boat and trailer only
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
    upstate N.Y.
    Yo Ralph , what's up ??
    why ask me ?
    May 2017
    Pittsburgh
    This 22 ft hull is essentially a larger more stable version of the 20 ft riot hulls. Very stable over rough water at high speeds.
    Bristol, WI
    What's your name and phone number? Could you please provide a link to your Craigslist add with the photos? I cant seem to find it.
    Larry Gempp Jr.
    May 2017
    Pittsburgh
    genegenre@gmail.com. the Johnson 225 is a trade from the buyer of my 300r. He says motor runs and planes on his boat but only able to hit 30 mph on a 22 ft pontoon so we'll have to look over the motor over the next couple weeks.
  12. #12
    Bristol, WI
    What did you trade it for? A 300R with a sportmaster lower unit on a 22 pontoon?...lol. just sent you email if you want to sell the package....
    Jr.
    Larry Gempp Jr.
  13. #13
    May 2017
    Pittsburgh
    Yeah, 300r on a 22 ft pontoon, Believe it or not! I didn't ask!! Only need the sports master and race version for boats over 85 mph as I understand. To each their own! Should still be able to hit about 65 mph not bad for a barge.
  14. #14
    May 2021
    Minnesota
    Quote Originally Posted by genegenre View Post
    If your 225 Johnson doesn't shake out that well I might be interested in it for a parts donner or a rebuilder. I am modernizing a couple of GT 200's.
    What do you think?
    Aaron
  15. #15
    May 2017
    Pittsburgh
    Absolutely, I will keep you in mind if that ends up being the case.
  1. Rapid Craft 21' Tornado
    By PORT in forum General Boating Discussion
    Last Post: 03-26-2004, 09:10 AM
  2. rapid craft 22ft tornado/ twister
    By ZRX in forum Technical Discussion
    Last Post: 03-31-2002, 12:57 AM
