Results 16 to 30 of 102
07-27-2021, 05:51 AM #16
think hes referin' to how fas tha coolin' water exits tha motor.. no restrictions ta slow it down enough ta do its job...
07-27-2021, 06:15 AM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-27-2021, 06:40 AM #18
have no idea what he means by "excessive coolant speed" means then...........
David - WI liked this post
07-27-2021, 09:11 AM #19
with the poppet stuck closed the motor is not passing enough water, the temp climbs.
1973 Viper - sold
1978 Viking - sold
1995 XB02
07-27-2021, 09:21 AM #206000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
07-27-2021, 01:22 PM #215000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
It's an assumption on my part.
in an Automotive application, if the coolant speed through the motor goes to fast, it can't transmit the heat from the motor to the coolant before the coolant exits the motor causing it to overheat.
So even in a race car there is either a thermostat or a restriction to slow the coolant down.
07-27-2021, 01:36 PM #225000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
The motor has 30 hours on it after a rebuild last winter. And lucky for me... being in the great white north where the air hurts our face 9 months of the year... No salt! LOL
I'm going to clean the poppet again and hopefully I can get through the end of the season before I rip it down for cleaning and inspection.
I'm just amazed that I'm having so many issues with this. BUT... if this stuff can sit in places and ride along before giving me issue again, then... well that's probably what's happening.
I'm surprised that with as much water pressure as the motor builds (easily pegs the gauge), that when the valve gets stuck, it doesn't blast the other crap out before I take the poppet out get it cleaned and try running it again.
07-27-2021, 02:02 PM #235000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Could you have the wrong spring in the poppet? Think the HP motors that ran poppets also ran a stiffer spring. Too stiff of a spring may not open enough to let the smaller trash pass easily.
ANTI40It's just an idea.
07-27-2021, 02:07 PM #24
understand how all that works but you can't have a "blockage/closed poppet" AND water exit to fast to cool........ maybe i jus misunderstood what ya said?
stuck open will heat at low speed. water moves too fast... stuck closed will heat at high speed.. not fast enough.Last edited by tlwjkw; 07-27-2021 at 02:16 PM.
DieselDood liked this post
07-27-2021, 02:39 PM #25
07-27-2021, 03:37 PM #265000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
07-27-2021, 08:36 PM #276000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
07-27-2021, 09:14 PM #285000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
07-27-2021, 09:16 PM #29Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
coolant flow speed going too fast is old wives tale.
Exit restrictions are either to build pressure or temp or both.
on an auto you need pressure to stop the pump cavitating at high speed.
check out the wp nascar engines run at..Last edited by powerabout; 07-27-2021 at 09:23 PM.
David - WI thanked for this postFishwhisper liked this post
07-27-2021, 09:22 PM #30
Poppet Valve
By Fisher77 in forum Technical DiscussionReplies: 2Last Post: 07-07-2016, 08:28 AM -
Mercury Tech: Poppet Valve kit - which one for this poppet?
By gmacrae in forum Technical DiscussionReplies: 4Last Post: 10-07-2014, 04:53 PM -
Poppet valve/relief valve issues 1978 2.4l Merc
By rujr in forum Technical DiscussionReplies: 2Last Post: 06-24-2013, 08:21 PM -
Mercury Tech: Poppet valve
By Ron.64 in forum Technical DiscussionReplies: 1Last Post: 06-26-2012, 05:03 AM -
Poppet Valve
By RICHARD TATE in forum Technical DiscussionReplies: 1Last Post: 08-06-2007, 04:29 PM
