Results 16 to 30 of 53
Thread: tell me what you think
07-26-2021, 02:02 PM #16Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
LakeFever liked this post
07-26-2021, 02:26 PM #17
You have an older style vst might wanna check these area's for filters
rprinzo thanked for this post
07-26-2021, 05:00 PM #18Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
When you’re running wide-open it’s getting plenty of air but not enough fuel, when you back off the throttle and it’s smooth it’s because it’s getting less air, the fuel you have is sufficient to make it run smooth. Fuel pressure sensor as close to the engine as possible put a gauge on the dash and drive the boat, when the boat starts acting up look at your fuel pressure gauge. If the pressure is not dropping then you’ll have to pursue other avenues. Sometimes boxes can act up if it detects low-voltage.
Just because this is new and that’s new and everything‘s new does not mean it’s working properly.
07-26-2021, 05:31 PM #19
07-26-2021, 05:40 PM #20
07-26-2021, 06:40 PM #21Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
I should’ve said black box the ECU. In the past I’ve had low voltage and it made the ECU box go crazy.
07-28-2021, 09:12 PM #22
07-28-2021, 09:19 PM #23
07-28-2021, 10:01 PM #24Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
The testing has to be done out on the lake with the boat running. When the boat starts acting up that is the time to look at the gauges. The gauges should be on the dash. Install the sending unit after all the filters as close to the fuel rail as possible. This will help you get pointed in the right direction.
phillnjack liked this post
07-29-2021, 05:39 AM #25
You have a stock regulator but the gauge says 90 psi
That should be around 36 to 38 psi
07-29-2021, 07:00 AM #26Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
I’m not sure what motor your running. I’m just looking at the plugs and what you’re telling me about the loss of power then letting off the throttle a bit and it smooths out. Years ago I had a similar problem I did not have a fuel gauge I later found the fuel filter had some type of object floating around and would occasionally restrict the fuel flow. If I would have had a pressure gauge at my dash I would have known exactly where to look or where not to look.
07-29-2021, 08:27 AM #27
07-29-2021, 08:32 AM #28
07-29-2021, 08:41 AM #29
one other thing thats happening is with the fuel line dissconnected at the motor, the pump bulb stays rock hard forever, connect to motor and it goes soft within minutes to completly empty. i guess what i can do in the driveway is connect the gauge ahead of each item in the fuel flow to see where its leaking down. it stayed at 90 lbs after the final filter, ill hook it up after the manifold and so on. and yes ill be spending the money for a dash gauge also
07-29-2021, 09:22 AM #30Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
I don’t have a squeeze ball. If you can find the problem in the driveway that would be great. I understand you don’t wanna spend the money. If you can plumbing a mechanical gauge temporary with a long fuel line up to the driver seat you can do it that way its not the recommended or safe way to do it but if you’re in a pinch.
