Results 1 to 2 of 2
    May 2021
    USA
    300 optimax prop setup
    Looking for info/direction on prop setup. I’m running twin 300 on a 25 Talon with 33 vented props. 50 hours on motors. I’m only seeing 5000 RPM’s.
    Central, PA
    If your going to re prop the boat, I would go to 28p props. I'd also switch from thru- hub to over- hub exhaust on a light setup like yours. Your preference would be how it handles with a chopper giving bow lift or a cleaver giving stern lift. With this set up you should turn you approximately 6200-6400rpm
  1. can you run through prop style with over prop setup
    By aggiestckl in forum Props, Setup, and Rigging
    Last Post: 10-08-2012, 06:43 PM
  2. New Motor setup (Optimax 225)
    By impactfishing in forum Props, Setup, and Rigging
    Last Post: 07-16-2012, 06:35 PM
  3. prop setup
    By sombeachjeff in forum Props, Setup, and Rigging
    Last Post: 04-30-2012, 09:21 AM
  4. Prop Setup
    By Guppy in forum Props, Setup, and Rigging
    Last Post: 09-14-2009, 08:14 PM
