Results 1 to 4 of 4
    Nov 2020
    Nj
    115Hp tower of power lower question
    On my checkmate predictor I have a 1984 115 merc tower of power on it the last time I was out at the end of the day I heard a grinding noise on and off which almost sounded like the starter gear was hitting the flywheel.today after going over everything I ran it on the water and in nuetral the prop was spinning and when I put it in gear I heard that noise I described so I shut it down. I removed the screws in the lower and it was almost dry with some dark water n metallic coloring.a few rides ago the case was full which has me baffled as to where all the fluid went. When turning the prop it has a gritty feel to it so I'm sure damage has been done to the gears.
    Question I have is do I have this rebuilt or is there other options of lowers to go with? Any help would be greatly appreciated.
    Attached Thumbnails Attached Thumbnails C036F7B5-4568-46CF-8DDC-09BDFBC4AA58.jpg
    Nov 2020
    Nj
ID:	490665I'm not sure why the pics came out sideways I just wanted to post for reference of the model engine
    Sep 2011
    Deplorableville
    There are some parts still around if you look at some old school mechanics shops. I have an 85 that is the same color scheme as that one. A buddy bought it new on a boat in 85 and I bought from him in 95 and it's still running strong. It is hard as heck to start sometimes and others it will fire up on the 1st or 2nd try. It has been by far, the best outboard I have ever owned. As far as that goes, it's the best engine I have ever owned.
    Feb 2003
    Auckland - New zealand
    I would say your best option is look for a good used lower. Special tools, cost of replacement parts etc. Plenty dead motors out there, try and stick to a swept skeg version.
    Peter Thomas
  1. Mercury Tech: hard starting merc 115hp tower of power
    By bestman53 in forum Technical Discussion
    Last Post: 08-12-2020, 03:26 PM
  2. Tower power of question?
    By Wcnors90 in forum General Boating Discussion
    Last Post: 11-30-2014, 08:57 PM
  3. 1975 115HP Tower of Power
    By scott reierson in forum Outboard Engines
    Last Post: 07-15-2014, 12:57 PM
  4. Tower of power stator question
    By Keebibear in forum Technical Discussion
    Last Post: 05-24-2011, 02:51 PM
