Results 1 to 15 of 30
07-19-2021, 03:20 AM #1
Who wants to speculate on what happened to THIS prop?
scott reierson liked this post
07-19-2021, 04:36 AM #26000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
I would like to say that its a crystaline failure in the blade root but the blade in the 7 o clock position is heeled over. The fracture line in all the blades is nearly identical. Did you hit something? No.
07-19-2021, 05:49 AM #3
I have destroyed many props over the years but very few done that well. Congratulations for a job well done.
RockTeam Junk
JBS, DanUmbarger liked this post
07-19-2021, 06:19 AM #4Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
how could it fail first time out..must be warranty...
07-19-2021, 06:25 AM #5
Interesting that the skeg and gearcase look untouched. Also appears to be a two engine installation. Hmmmm.
1992 Progression 22
Mercury Racing 250R
07-19-2021, 06:43 AM #6
Lab work... reduce diameter to get engine in RPM range!
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-19-2021, 07:22 AM #7
Blades are bent at the leading edge opposite of rotation so it was in reverse or the r/h prop is also destroyed
07-19-2021, 07:23 AM #8Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
When the prop meets the road......
07-19-2021, 07:29 AM #95000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 335
- 134
- 7 Post(s)
Jaws is still alive and well.
07-19-2021, 08:21 AM #105000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
07-19-2021, 09:31 AM #116000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Man that’s an interesting failure. I actually don’t think it was caused by impact with an immovable object. Looks to me like a fatigue failure. The crack initiated at point A in the attached pic. B shows beech marks where it propagated and C is the final failure. One interesting point is that the blades we can see appear to have failed in a very consistent manner. The final failure is roughly half the original cross-sectional area, indicating they are normally run at about 50% of their strength. It is true that the final failure is in the reverse direction but this could just be coincidence as that was the load state at the time when stress > strength. It was going to fail soon whether in forward or reverse.
My best guess is that all blades had fatigued for some time due to extended surfacing and/or material deficiencies and/or stress riser due to machining. A hardness check could rule out one of those and a microscope could rule out another.
07-19-2021, 09:43 AM #12
kellytheaker, powerabout liked this post
07-19-2021, 10:05 AM #13
Also looks like they cut the hub maybe they nicked the blades all in the same area with the lathe... def started in the smooth almost cut looking areas at the trailing edge.
07-19-2021, 10:41 AM #145000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Armor plated manatees out for revenge?
ANTI40It's just an idea.
07-19-2021, 12:35 PM #15
kellytheaker liked this post
So this happened............
By rjdubiel in forum General Boating DiscussionReplies: 14Last Post: 08-27-2019, 07:41 AM -
What happened to my gel?
By Boz in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 10-15-2009, 05:30 PM -
What happened to the What happened thread?
By in forum General Boating DiscussionReplies: 43Last Post: 03-02-2002, 02:52 PM
