Results 1 to 2 of 2
Thread: Tell tale question
07-18-2021, 07:04 PM #1Member
- Sep 2019
- madison wisconsin
- 31
- 10
Tell tale question
I have a 1988 mercury 90hp 3cyl. The dealer says the tell tale fitting where it connects to the cowl is un available . I was going to machine one on my late like a bulk head fitting. Does the size of the hole make much difference- affect cooling or water pressure? Does anyone have one of these late 80s motors they could check the ID of the tell tale with a drill bit.
07-20-2021, 12:26 PM #2Junior Member
- Nov 2012
- springfield--ky
minnow is right size dont matter, you can just run a small hose thru the hole without making a fitting if you dont want 2 go 2 the trouble,, its only on there to show that your watter pump is working, make shur the stream is solid with no bubbles in it or your pump may need attention,, good luck..
Mercury Tech: 3.0 Liter Tattle Tale Squirter Question
By JohnR in forum Technical DiscussionReplies: 5Last Post: 05-31-2013, 03:52 PM -
A Prince's Tale
By mirage243 in forum The Scream And Fly LoungeReplies: 0Last Post: 08-03-2011, 09:44 AM -
Rooster Tale
By PHISH in forum General Boating DiscussionReplies: 21Last Post: 03-08-2007, 05:59 PM -
To Tale or not To Tale?
By VIKING in forum Technical DiscussionReplies: 1Last Post: 05-18-2004, 11:42 PM
