Results 61 to 75 of 76
11-26-2021, 06:41 PM #61
With a 29 mine stops at 8200. Poor thing saw a lot of 8200 on the jasper run last year. 3 days of 8200, that was after a 2 summers of 8200. Then I ran it out of gas at 8200 and scurvied the bores a little. Now it is getting a horn and some more 8200.
11-26-2021, 07:23 PM #62
If I get three summers out of 8200 I’ll be very pleased. Even 7500 should be plenty I think
11-26-2021, 07:32 PM #63
Been using the 1.5 mm WSM pistons at .005 and try to keep the water temp at the tops of the head 130-140 in summer water temps. Other than the new pistons,gaskets and wrist pin bearings everything else came out of boxes of stuff laying around. I'm pretty pleased with it.
11-27-2021, 08:59 AM #645000 RPM
- Sep 2014
- Iowa
- 280
- 16
- 44
- 89
11-27-2021, 10:49 AM #65
That's exactly what I've done to this new motor I just put together, the block was ported , all new holes , 1.5mm wsm , new rod and wrist bearings, and the 2 small crank bearings , everything else just parts laying around , started life as 240 sport jet. Hopefully she'll b strong , I know it's got pretty big shoes to fill because the little "200" ran very well
04-01-2022, 05:57 PM #66
04-06-2022, 06:48 AM #675000 RPM
- Dec 2009
- middle tennessee
- 215
- 68
- 28
- 189
- 164
Nice, glad this thread isn't dead! Keep us posted
04-06-2022, 07:42 AM #68
Ya I almost bought another motor just to speed this all up but don’t need more clutter kicking around so I’ll start with this one and hope it works out ok. I’ll update soon as I get the block back
04-06-2022, 03:45 PM #69
04-06-2022, 04:38 PM #70
No it’s coming back with fresh cylinders and pistons the assembly I’ll do myself and update this thread when I get to it. Over time I will work this block more or more than likely buy another block or complete motor to build on the stand while I run this one. I did the rod slots and opened up the exhaust dump and the mid plate. That’s the extent of the block mods for now on this build. Supporting mods will be reeds and stuffers, head studs, oil injection delete. I’m hoping this should still run well on the factory computer at 23 degrees timing. I want to keep it simple for now, get it running and on the water this year. I measured the height of the exhaust ports and they were all identical so I left those alone too.
rgsauger liked this post
04-06-2022, 04:49 PM #71
I've also noticed with staffers, it seems to run outta steam faster on top , mite gain little on bottom but sacrifice it on top , that's just my experience from installing and removing em , and with the reeds. Not sure who ur using but get a thinner Reed if possible, I noticed bout 300rpm loss with the thick reeds , then I had a buddy make me sum in 3 diff thickness, and when I went little thinner rpm came back. Just don't go to thin and risk burning em easier. Take it as u like. But that's just from my testing and watching my rpms , when I built my promax. I left stuffers out and used a .019 Reed I believe, I also have a .020 and .023. Which r all thinner than Carsons sport reeds but he makes diff thicknesses also. Just food for thought
04-06-2022, 05:51 PM #72
I did not know that about the stuffers thanks. I’ll gladly leave them out if it helps up top I’m not too worried about bottom end power I’m sure there will be plenty. My 2.0L had enough grunt for me down low if I want to launch hard I’ll stick a ski prop on it. What supplier do you suggest for the thinner reeds? *edit* I saw there your buddy made them. I’ll ask Chris about these I was planning on using his anyways. Great guy
04-06-2022, 06:11 PM #73
Yes Chris is top notch. Been using his reeds long time, just didn't in this last motor. Just tell him u Want a little thinner Reed than the sport he sells,
If u want put ur staffers in and run em and get used to the motor , then take em out and see what u get, every motor is diff even if they same , member on here lost rpm up top but he thinks it's the stuffers that did it to his motor ,and I'm sure the thick reeds lost rpms on my motor cause I didn't have stuffers in at that time.
Best thing to do ,is set up 2 Intakes , 1 with thicker reeds and stuffers. 2nd with just thinner reeds, start with stuffed Intake, get familiar with motor , then swap Intake, and see the difference. That's the best way and it swaps pretty quick
06-26-2022, 05:46 PM #74
Bought another 200FF today. Its a 99 and one hole is lowish on compression according to the seller who is a super decent guy so i take him at his word. I have no idea whats going on with my machine work on my block its still at the machine shop so im hoping the block on this new one isnt scored up and its just a stuck ring. If thats the case i will get this new one reassembled to factory spec only adding steel cage bearings and rod bolts. I will probably even leave the reeds and whatnot all oem. I’ll get some pics for you guys when i get another stand built
06-27-2022, 05:01 PM #75
Did a quick bore scope and everything looks clean in the cylinders. Piston tops are black and no signs of melting or scoring that i could see. Going to run compression and leak down tests on it see whats what
Totally new to Jet Boating, Lots of questions
By iloveitloud in forum The Scream And Fly LoungeReplies: 0Last Post: 06-20-2010, 08:29 PM -
Need lots of race pics, Please!
By Alan Power in forum General Boating DiscussionReplies: 11Last Post: 10-20-2005, 02:33 PM -
OMC gurus lots of questions
By BASSIN in forum Technical DiscussionReplies: 24Last Post: 11-02-2004, 08:55 AM -
Build it light,Add lots of HP
By Sharkey-Images in forum Technical DiscussionReplies: 2Last Post: 07-29-2001, 09:08 AM
