Results 31 to 45 of 76
08-08-2021, 06:50 AM #31
The plastic gear on the crank stays yes?
08-08-2021, 08:35 AM #32
I believe so to take up space for less crankcase volume. I doubt you would notice the difference
1973 Viper - sold
1978 Viking - sold
1995 XB02
LakeFever thanked for this post
08-08-2021, 08:54 AM #33
That’s what I figured but wanted to confirm
08-08-2021, 09:06 AM #34Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
Here’s what an exhaust chest should look like.
tnelsmn, DieselDood liked this post
08-08-2021, 09:20 AM #35Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
Stock looks a little choked up.
tnelsmn liked this post
08-08-2021, 10:04 AM #36
I would go that far but realize there are limits to the steel bore at extreme RPM as well as tuning challenges. I’m basically aiming to get as close to a 225 promax as I can and run a promax ecu and hope for the best.
08-08-2021, 01:16 PM #37Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
How many RPM do you want to turn? I really don’t know much about a 200 but I have 2.5 260s with steel sleeves. I thought I saw an oiler crank in your motor?
08-08-2021, 01:25 PM #38
The ecu I have has the limiter set at 7600. The crank I have is an oiler the motor from factory is a 200FF efi fishin mota
08-08-2021, 01:51 PM #39Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
I think the oiler crank is the reason there’s a RPM limit. I guess you need to stay in your comfort zone.
08-08-2021, 02:42 PM #40Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Stoker, how often (percentage) do the cut on blocks get cracks in the ports?
08-08-2021, 03:19 PM #41
I’m deleting the oil injection and going premix. I was asking today about the plastic gear whether it should stay on the crank or be cut off. As Forbes mentioned I am going to drive the bronze bushing out and fill that void with epoxy as well as fill the cavity the oil pump shaft takes up to equalize the volumes. Going to finish opening up the plate and detail the block exh dump as well as clean up the casting flash and do some work on the rod slots and that’s about it as far as porting goes.
i was all set to go hog wild but figured it better to get a solid runner first, then if this doesn’t do it go wilder on the next oneLast edited by LakeFever; 08-08-2021 at 03:24 PM.
08-08-2021, 04:17 PM #42Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
08-08-2021, 04:25 PM #43Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Near the exhaust port area is where I was referring to. I had a 2.4 radically ported. It ran good but cracked after a 100 hrs or so.
08-08-2021, 05:44 PM #44Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5319
Was it a Bridgeport 2.4?
08-09-2021, 09:11 AM #45Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Yes, a bridgeport.
Totally new to Jet Boating, Lots of questions
By iloveitloud in forum The Scream And Fly LoungeReplies: 0Last Post: 06-20-2010, 08:29 PM -
Need lots of race pics, Please!
By Alan Power in forum General Boating DiscussionReplies: 11Last Post: 10-20-2005, 02:33 PM -
OMC gurus lots of questions
By BASSIN in forum Technical DiscussionReplies: 24Last Post: 11-02-2004, 08:55 AM -
Build it light,Add lots of HP
By Sharkey-Images in forum Technical DiscussionReplies: 2Last Post: 07-29-2001, 09:08 AM
