Results 1 to 7 of 7
Thread: Crankshaft Balancing
07-17-2021, 10:23 AM #1Member
- Jul 2018
- CORPUS CHRISTI TX
- 39
Hey Guys,,,does anyone do crankshaft balancing or is that something thats only done @ the factory?
07-17-2021, 08:55 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
This is how I do it..... my wife gets mad at me......
https://www.youtube.com/watch?v=vROdVsU_K80
rock liked this post
07-18-2021, 07:55 PM #3
07-18-2021, 07:56 PM #4
Monty racing does them.
michaelogden thanked for this post
07-18-2021, 08:01 PM #5
07-18-2021, 11:36 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Don't ya wish Mercs could take such a beatin'..........
07-24-2021, 08:48 AM #7
Still sore I didn't post pitchers of "the witch's nose" modification on a sporty ... ???
I'll say it again , I didn't invent it , so I'm not free to blab it .. perhaps that's why people trust me with their intellectual property ..
Crank balancing ....
Been discussed here before , maybe you should have spent half as much time using the search function as it took you to whine about the washing machine ..
OP .. You wont find many shops that have bobweight's that will fit a 1.000" rod journal , you'll need to bring your own adapters and light weights .. the big washers won't be needed.
A 120* crank for the most part is neutral , and can be dynamic balanced. I can tell you that a stock crank will jump out of the blocks and hit the floor .. it's as bad as that washing machine .. so no smart azz comment , just fact ..
However , if you wish to deal with the end to end or secondary amplitude , you will need to build weights and spin it up.
Hines recommends 30 to 50 percent .. I have always done outboards like Big Block Chevy's .. and went 52 percent .
https://www.hinesindustries.com/imag...procalmass.pdf
keefallan liked this post
Yamaha Tech: Crankshaft Balancing
By LINKS in forum Technical DiscussionReplies: 28Last Post: 03-02-2021, 09:39 AM -
By team fountain in forum Technical DiscussionReplies: 7Last Post: 08-20-2011, 12:43 AM -
OMC crankshaft balancing(you there AL)
By Roddles in forum Technical DiscussionReplies: 4Last Post: 08-15-2005, 01:55 AM -
balancing
By david laser86 in forum Technical DiscussionReplies: 90Last Post: 10-18-2004, 11:30 AM -
Balancing
By XBuddawg in forum Technical DiscussionReplies: 18Last Post: 01-02-2002, 09:13 PM
