Results 1 to 5 of 5
07-16-2021, 08:42 AM #1New Member
- Jul 2021
- NY
Mercury Inline 6 115HP - Strange Noise, Please Help
Hello bright minds and good people of Scream and Fly. This is my first post so please take it easy on me if I ask a stupid question.<br>I got a 1984 Mercury Tower of Power Inline 115hp. <br>It just started making a strange noise that I nor a local experienced Mercury mechanic could pin point the cause of. In all gears F-N-R and responsive to increased throttle (increasing in pitch) it makes a "squeaking and almost whining/choking noise". <br>The noise just appeared out on the lake one day and hasn't gone away. The engine has lost no power or performance and both the mechanic and I agree its not the dreadful "knocking" noise. I asked about the top or low end bearings and he said, "no doesn't sound like any bearing issue i've ever encountered". <br>It appears to come from the top end, but we both agree anything along the drive shaft can make it tricky to find exactly. I pulled the flywheel changed the shaft seal and top end cap o-ring, no change in sound. <br>Any advice or thoughts would be appreciated.
07-16-2021, 08:53 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Rear bearing on the R gear in the lower uint......had one drive me Crazzy..... yepp.
07-19-2021, 08:15 AM #3New Member
- Jul 2021
- NY
Well it would have been a long way down the check list before I got to that, I appreciate the advice. To clarify the bearing in question is circled in red?
07-19-2021, 02:55 PM #4
if you cant or don't want to fix it, I have a l lower off of a 1981 that I will never need. You can have for $50. You just have to come pick it up
DACKS thanked for this post
07-19-2021, 07:20 PM #55000 RPM
- Dec 2008
- Coldspring, TX
- 114
- 13
- 28
The inlines went through a lot of pistons, rarely a crank bearing failure.
WTB Inline 6 Merc 115HP-150Hp or OMC V-4 115HP-140HP
By mragu in forum Engines WantedReplies: 5Last Post: 05-28-2021, 10:58 PM -
Mercury Tech: 1979 Mercury Inline 6 115hp
By bestman53 in forum Technical DiscussionReplies: 8Last Post: 07-09-2020, 07:20 PM -
Mercury 115hp inline six powerhead..
By janihei in forum Parts WantedReplies: 1Last Post: 07-04-2016, 09:11 PM -
OMC Tech: Couple questions: Strange noise when decelerating
By polvo in forum Technical DiscussionReplies: 33Last Post: 02-19-2010, 07:15 PM -
Mercury Tech: Very strange noise 2.4 200
By transomstand in forum Technical DiscussionReplies: 14Last Post: 11-12-2009, 10:14 AM
