Results 1 to 13 of 13
07-15-2021, 11:46 AM #1
3.6 GT V8 in race car - torque/hp V's RPM needed
Hi - Pleased to say the Evinrude E300CXCUR engine is powering the sports car VERY well.
Currently I have the standard power head installed, not the race version.
I am trying to re-set the CVT transmission to this engine and it would help - save me a lot of time if anyone has a print out of a dyno test of an "Out of the box" V8.
Thanks
Peter
07-16-2021, 09:00 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Yes.... I have a friend that may be able to help.......will ask him.
Hillclimber thanked for this post
07-17-2021, 12:42 AM #3
07-19-2021, 04:51 PM #4
Doesn't seem like you are getting a lot of responses, so this is what I have to offer up. This was the dyno sheet from my 4.0 liter Monty Racing V8 with mid-bore carbs. It's a bit hotter than a stocker, but I'd imagine the curve are similar to stock as to where peak hp/tq is made. This was his "lake motor" setup for a heavy boat.
Keith-
Forkin' Crazy liked this post
07-19-2021, 07:29 PM #5
I’ve been holding back on my “guesses” compared to what you’re looking for but after seeing Keiths post I think he might be close.
For stock, I’d take 1000 RPM off of both horsepower and torque curves.
I’ve intentionally left your thread alone hoping that Racer/Al Stoker would reply.
He’s probably your best bet on this site for an actual Dyno curve.
Try sending him a PM.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
07-19-2021, 08:45 PM #66000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
Hillclimber, Instigator thanked for this post
07-20-2021, 01:08 AM #7
Hi All
MANY THANKS for your replies/info, it will help a lot in the CVT fine tuning. I did PM Al, but his old files are elsewhere.
07-20-2021, 12:13 PM #8
powerabout thanked for this postInstigator liked this post
07-20-2021, 06:35 PM #9Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Sorry I dont have any 3.6 dyno sheets here at home they are in storage out in Ca. What I did find was a stock 4.0 with the idle hole plugged off. Also not all dynos even when calibrated will read the same due to things like exhaust system room air etc. That being said this engine had torque peak at 4500 and peak HP from 5500 to 6250. From memory the 3.6 peak torque was at 5000 stock and peak HP from 6000 to 6600. Hope this helps.
V pads thanked for this post
07-21-2021, 02:36 AM #10
Instigator, racer liked this post
07-21-2021, 06:29 PM #11
Many have responded to the dyno results you asked for, so going back to the CVT, how are you're weights set up as far as when the powerband of this beast hits?
07-22-2021, 02:48 AM #12
Hi - Here is the car getting off the startline at Shelsley Walsh hillclimb. Parts of the hill are 1 in 6 gradient, so still fine tuning the CVT: https://www.facebook.com/peter.hubba...75129/?__cft__[0]=AZXsFBuYtEb4cjwvo6DMHG4lcCdW2MUnPXSsrDaDtukBpiBlfyPWNUmM6k0Iqz1o-fmDbyiEIE6lX0z7gfREjNKtwbyBX7nshc7UrCHc4ABXRDjxkz4WhenM5FCRgfTodT7T7icAhxIPKPvR6MV7AhkvjI64tQzjrB26x mn4wI7h9XBHj6NKowSzJwgOXSO47XwI9LhTaRVwc-wXopSf9GPr&__tn__=-UK-R
07-22-2021, 05:57 AM #13
We will require onboard video and audio
Yamaha Tech: Yamaha f250 3.3l torque specs needed
By cactusth in forum Technical DiscussionReplies: 0Last Post: 03-22-2016, 05:09 PM -
Standard vs. Solid Race Flo-Torque hubs
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 3Last Post: 12-03-2011, 06:07 PM -
Torque tab needed?
By 82RAYSONCRAFT in forum General Boating DiscussionReplies: 5Last Post: 05-31-2006, 11:31 AM -
torque spec needed for V4 omc
By m-11 in forum Technical DiscussionReplies: 3Last Post: 05-23-2004, 07:40 PM -
Torque #'s Needed
By 4Speed in forum Technical DiscussionReplies: 2Last Post: 06-15-2003, 04:05 AM
