Results 1 to 5 of 5
Thread: 250 sho cylinder pitting
07-14-2021, 08:10 PM #1Junior Member
- Jul 2012
- sc
Have any of you experienced pitting in the plasma cylinders of the Yamaha sho motors? Had a friend contact someone with Yamaha tech services and they have seen it but don’t know what the cause is. 450-500 hundred hours and the motor started Smoking at idle leak down shows 12% and compression was 150. Pulled the head and found one cylinder with pitting on the cylinder walls. Piston top and head and valves in great shape. Yamaha said it would have been covered but it is out of warranty.
07-15-2021, 10:46 PM #2
Yep have pics of them so rotten a couple started talking to the adjacent cyls. I’ll dig up the pics tomorrow they were also low hour “plasma” cyl 4.2L. If any salt makes it to that cyl the “plasma” seems to remove itself from the aluminum sleeve rendering the block useless unless a steel sleeve is installed. Most can be saved with steel sleeves but it’s not cheap or easy.
07-25-2021, 12:50 AM #3
The newer these motors get the more they become throw away motors. They are good reliable engines unless something goes wrong with corrosion usually. We have rebuilt a few of them but the bore has to be pristine just so you can run a diamond hone through it for factory rings. I would really like to know what the "plasma" coating is made of since they wont tell me over the phone.
07-25-2021, 07:41 AM #4Junior Member
- Jul 2012
- sc
I spoke to a company that does nikasil and they said they can repair the cylinders but I would have to find oversized positions. Nikasil is used on a lot of the motorcycle engines I have had built and never had an issue.
07-25-2021, 10:45 AM #5
drive shaft pitting
By nelson edens in forum Technical DiscussionReplies: 6Last Post: 07-12-2016, 06:42 AM -
Mercury Tech: Minor Pitting
By icatchbigbass in forum Technical DiscussionReplies: 6Last Post: 11-16-2015, 11:48 PM -
225 promax driveshaft pitting
By des in forum Technical DiscussionReplies: 0Last Post: 04-11-2009, 05:39 PM -
Crank Journal Pitting
By marathon6 in forum Technical DiscussionReplies: 15Last Post: 12-18-2007, 01:17 PM -
Under Pump Drifeshaft pitting
By Tom Foley in forum Technical DiscussionReplies: 7Last Post: 12-16-2007, 06:35 PM
