Results 1 to 5 of 5
Thread: 1993 Bullet 19vee set up
07-05-2021, 10:06 PM #1New Member
- May 2021
- Missouri
07-06-2021, 07:20 PM #2New Member
- May 2021
- Missouri
Anyone have opinions, or advice? Should I move this to a different area on the website?
07-16-2021, 09:37 AM #3
Depends how heavy that Johnson is, I have a '90 20vee that I temporarily put a 3.0 Merc 225 EFI on. Motor weighed around 490lbs, I had to put 100lbs of sand under the front deck and install a hydrofoil to get the boat to run right and set level in the water. All in all it wasn't worth it, the vee hulls were never meant to have a heavy motor on them because they don't have the third brace in the transom like the mid 90's bullets do. The perfect motor for a vee boat is a 2.5 v6. Anything around 400lbs or under would move that boat plenty fast enough. I just repowered with a '95 XRi 200, motor is sub 400lbs and allowed me to remove the sand bags from the deck and shed around 200lbs all together.
rgsauger liked this post
08-24-2021, 10:19 AM #4Member
- Oct 2018
- TX
- 36
Maybe a little late but what Sam Hain has said is true. For one, Bullet had a warning decal on them up until 95/96 that stated NOT to put on a heavy motor (3.0L or larger). They added a third transom brace in 95/96 which changed that. The light weight of those boats make them run great with a 2.5L. Finally, I'm a Bullet guy thru and thru, have been since 1992. I fish, but in my younger days I also wanted the speed you could only get from a Bullet/Allison/ Stroker bass boat. Now much older I like to have the power/speed when needed but I also care more about the fishing. That being said, putting an old Johnson on a Bullet is no different than putting an inline 4 banger in a Vette!! If you want speed, and guessing you do since you bought a Bullet, then why put on something you will not be happy with!!
sam hain liked this post
09-26-2021, 09:57 PM #5
Slide a 200 Promax on that thing and get ready to learn how to drive!
1993 laser 388le boat and 1993 mercury 2.5l efi 280 offshore
By Trikmit in forum General Boating DiscussionReplies: 2Last Post: 02-28-2017, 07:44 AM -
1993 Bullet 20 VEE 225 Promax/sportmaster southern CT
By Rich in forum Hulls up to 20'Replies: 2Last Post: 07-20-2015, 06:48 AM -
Chine Walkin 85 Bullet 19Vee w/ 175 Merc Black Max
By Bwp1228 in forum Props, Setup, and RiggingReplies: 80Last Post: 10-17-2013, 07:09 AM -
1993 20 XD Bullet with a 1998 Johnson 225 Looper
By dirtstyle52 in forum Props, Setup, and RiggingReplies: 1Last Post: 05-12-2013, 06:17 AM
