Results 1 to 2 of 2
07-02-2021, 01:28 PM #1Junior Member
- Sep 2015
- Milwaukee
Mercury trim help - motor to pump
Hi, I have a 1983 150 v6, this is mine pictured here... I have a trim pump that came with it, also pictured here.. The pump appears to be newer version and have a much larger 1/2 x 20 female thread with counterbore for o-ring. The lines coming out of motor under transom appear to be 3/8 x 24.
Do I have the wrong pump?
Does this newer style pump use quick connects? If so, can I buy the adaptors and make it work with the existing stock lines?
Thank you, scream and fly..!
08-01-2021, 09:27 AM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
I HAVE a 83 150, the hard lines from the motor have two different fittings, to avoid mismatching. you might want to take a close look, at a glance they look the same. lines will match, ends to pump, ends to engine r & l.
