Results 1 to 15 of 23
07-02-2021, 12:17 PM #1
WTB offshore johnson/evinrude V6 offshore exhaust
Looking for 1989 or around that era offshore mid sections for 3.0 Looper. Looking for complete engine as well. I'm trying to reconstruct that limited edition second effort style engine.
Aaron
07-02-2021, 08:11 PM #2Junior Member
- Aug 2017
- Colorado
- 18
I don’t recall the 3.0 liter engines ever being made with a factory cast exhaust snout like the 20” midsection on the V8s of that time did. I’m pretty sure that Second Effort offered a bolt on exhaust snout for the V6s but my friend’s second effort “Limited Edition” 1988 V6 looper from Second Effort was pretty much stock other than the nose cone and lightweight cowling, keeping in mind that those versions were the ones with full OMC warranty marketed to the public.
07-03-2021, 02:52 AM #3
I think you're right. I've looked through quite a few pictures and it seems that it was just a screw on snout. Did they just drill a hole in the lower exhaust liner? Does your friend have any pictures of his limited edition?
07-03-2021, 05:39 PM #4Junior Member
- Aug 2017
- Colorado
- 18
My friend has long since sold the boat and I don’t have any pictures of it that are other than far away which probably won’t give you mutch help. I might be able to do one better. I believe I have a copy of their 1987-88 catalog. Let me check and if you don’t have it but would like it, pm me with an email and I’ll scan and send it.
07-03-2021, 08:48 PM #5
This is a video of what I'm attempting to recreate. I love the way these engine sound and I am making an attempt to nail down what they had done to the exhaust systems. I've already purchased one 1989 gt200 that has a weak cylinder and are searching for another to match.
https://youtu.be/ROKlun2cMd8
I have seen the 1989 second effort catalog, are you referencing a 1987 88 second ever catalog that you might have? It would be interesting to see what they had.
Aaron
07-04-2021, 09:30 AM #6Junior Member
- Aug 2017
- Colorado
- 18
I have the volume 3 catalog which may be the same version as you’ve seen. As an FYI, I purchased, brand new, a Johnson GT200 in 1987 (2.7 liter). The only difference really between the GT and non GT 200 and 225 were spacers instead of baffles on the airbox and higher mid range and high speed jets. It sort of sounds like you’re only looking for that GT type model, and please correct me if I’m saying something you already know but you could expand your search to 1988-1992 for any 3.0 V6 looper. Then in order to create a non-modified version of what’s in your video, you’d want to do the exhaust snout (available from Bob’s machine shop), a lightweight cowl (I actually have a mold for a lightweight V6 cowl that I made 20 years ago), and if you really wanted to get fancy, scare up a set of GT airbox spacers to switch out the baffle for but you absolutely have to change Jets as well or you’ll burn up the motor.
Regarding the exhaust snout, what I’ve seen on the Facebook groups and I’m sure that Bob’s Machine shop could counsel you on is that a hole saw, say around 2 1/2”-3” is used to cut a hole in the exhaust housing and inner liner. I’ve never done it but I’ve seen some FB posts that show pics of people doing it.
07-04-2021, 10:14 AM #76000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 340
- 173
Those engines do sound awesome. Those are almost certainly aftermarket add-on snouts. I have a couple V8 20" mids, if you want some pics and measurements to copy their cast-in snouts let me know. Yes, you can cut a hole in the inner liner to send more exhaust out the snout. It will be LOUD.
Matt
07-04-2021, 05:14 PM #8Junior Member
- Aug 2017
- Colorado
- 18
07-05-2021, 12:08 PM #9
Sorry for the delayed response , I was busy rattling my chains of freedom! If It's not a terrible amount of work that would be interesting to see pictures. I kind of wondered if the V8 lower sections could be attached to the V6 head. I talk to Monty and he recommended to keep these engines around 300 horse for daily use. Having the bigger lower sections would make everything more reliable in theory but it would be more weight as well. I will start tearing into this engine shortly after it arrives so that I can have a better picture of what I'm dealing with.
So far the latest thoughts concerning modernization is to experiment with etec cylinder heads and Bosch direct injectors. The crankcase will have to receive some sort of lubrication so I'm thinking of using regular fuel injectors to deliver 10 to 20% the premix fuel through the crankcase and the other 80% of the fuel will be direct injection at the cylinder head, probably 85% ethanol. I'm thinking the premix solution will be the high quality oil around 32 to 1 or 24 to 1.
What are your thoughts?
Aaron
07-05-2021, 12:14 PM #10
Thanks for the PDF! And thanks for the download of info on GT versus standard. I should have made mention that these engines are going to be modernized with fuel injection and such so there won't be any carbs to give troubles! Is that mold of the Cowell a replica or is it a custom Cowell all together?
07-05-2021, 12:16 PM #11Junior Member
- Aug 2017
- Colorado
- 18
07-05-2021, 12:30 PM #12Junior Member
- Aug 2017
- Colorado
- 18
It’s pretty darn close to the Second Effort cowl. I modeled it after my buddy’s old cowl but I didn’t like the louvers on the top because when it rained, the inside of his engine would get wet so I left the top smooth and opened up the louvers in the back which weren’t open on the Second Effort cowl. Not great photos but this is one I pulled from the mold and painted Johnson White.
07-05-2021, 04:26 PM #13
07-05-2021, 04:42 PM #14
ssv1761982 liked this post
07-05-2021, 05:54 PM #15
Evinrude OMC looper offshore mid exhaust mod by Michael Chapman
By mrichartz in forum General Boating DiscussionReplies: 61Last Post: 04-11-2020, 07:15 PM -
OMC Tech: F1 /Offshore V8 exhaust
By powerabout in forum Technical DiscussionReplies: 39Last Post: 11-19-2017, 03:34 PM -
280 offshore exhaust
By hastings in forum Technical DiscussionReplies: 3Last Post: 05-06-2009, 09:53 AM -
going to offshore exhaust
By tomoad in forum Technical DiscussionReplies: 0Last Post: 04-10-2008, 06:28 PM -
offshore exhaust snout vs relieved exhaust
By STVBOY in forum Technical DiscussionReplies: 3Last Post: 10-11-2001, 07:57 AM
