Results 76 to 90 of 120
Thread: Mirage, 260 setup
09-05-2021, 09:50 PM #76Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
I expect a full report.
duckrazee liked this post
09-06-2021, 09:17 PM #77
Well it ran great again today! Not sure what cleared out, but so far so good!!
Can't Never Could Till It Tried
09-07-2021, 11:33 AM #78Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
Congratulations, you fixed it stay safe.
09-08-2021, 06:37 AM #79
Now for for fun part!! Tinkering, and trying different props, and setups. Thank yall again for all the help and patience. Means more than you know!
Stoker boy liked this post
11-25-2021, 03:16 PM #80
What are your numbers so far? Just trying to compare and see where we can all improve.
I finally got my '90 mirage/260 set up *fairly descent* imo.
10" setback, 15" mid, big window CLE.
2-1/8" above the pad seems to be the fastest and best handling. I loose water pressure at about 2-1/2" above the pad, but the boat is more squirrely up there and no faster.
So far on my 3rd time out I hit 109mph with a 28 chopper at 8200 rpm. Did that real consistent about 6 or so passes. The boat is real stable from 90 to 109 mph, the most wobbly is around 60 to 70 mph.
Does anyone know how these hulls do over 110 mph? does it get squirrely?
Is it even realistic to get much over 110 with a 260?
11-26-2021, 06:45 PM #81Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
stoker2001 liked this post
11-26-2021, 06:50 PM #82Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
561 boat back in the day with a 260 and a little spray ran 128 MPH. Center steer 580 pound bare hull.
Its close to a 96 or 97 model.
11-26-2021, 07:00 PM #83
11-26-2021, 07:14 PM #84Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
Kevin‘s not trying to run the real big numbers any longer. At least that’s what he tells me.
11-26-2021, 07:18 PM #85Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
When a motor is set up for Delta running it’s different than running drag races. Kevin can run over 110 if he wants to.
11-26-2021, 07:20 PM #86Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
11-26-2021, 07:48 PM #87Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
11-26-2021, 07:54 PM #88Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
This Mirage bare hull 580 LBS stock drag motor with a little spray ran 125 MPH. It was about a 96 or 97 model. I know there are deck changes from 1990 models compared to a later model Mirage I believe there are some small changes to the bottom as well.
11-26-2021, 08:47 PM #89
Yeah my bottom looks way different than Kevin's. It looks like there's 3rd step in the center pad. Not sure if that was factory or if someone added it. 30 years later who knows what all has been done.
11-26-2021, 09:42 PM #90Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5315
I know Kevin bought his hull new. He has never mentioned doing any modifications to the hull. But I never asked him. Maybe? I will ask.
25two.stroke liked this post
Mirage Jag Setup?
By OntarioStreamin in forum Props, Setup, and RiggingReplies: 20Last Post: 11-07-2013, 09:56 AM -
mirage jag setup?
By superryan in forum Props, Setup, and RiggingReplies: 18Last Post: 03-10-2012, 02:59 PM -
90 mirage 2.5 200, setup
By @quaholik in forum Props, Setup, and RiggingReplies: 11Last Post: 09-14-2011, 05:20 PM -
Mirage Setup
By Peter J in forum Props, Setup, and RiggingReplies: 13Last Post: 11-26-2008, 11:19 AM -
Setup for Mirage ???
By Mirage in forum Props, Setup, and RiggingReplies: 1Last Post: 12-06-2001, 01:33 PM
