Results 46 to 60 of 120
Thread: Mirage, 260 setup
08-14-2021, 08:49 PM #46Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
Timing.
08-14-2021, 08:53 PM #47Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
Timing.
duckrazee liked this post
08-15-2021, 08:41 AM #48
08-15-2021, 04:00 PM #49
Took it to the river to test it, and of course the fuel pump won't come on... haha I didn't even mess with the fuel pump... getting 12.5v to the pump. Not sure whats up. Frustrating.
Can't Never Could Till It Tried
08-15-2021, 04:16 PM #50Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
Is it a Bosch 044 pump? I think it’s the factory pump used on a 260. I had one that sat for a while, same thing, I tapped it a few times and it started working. It’s not a bad idea to use a relay in the pump system, although I’ve done it without and it still works. I’m thinking you probably just get better amperage to the pump. The relay was a must when I went to a Weldon Fuel Pump.
08-15-2021, 05:09 PM #51
08-15-2021, 06:28 PM #52Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
It might be a Bosch 984. The thread looks like it’s maybe a 3/8 but it’s not, it’s metric.
08-15-2021, 06:47 PM #53
08-15-2021, 06:58 PM #54Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
If you need to replace the pump buy it from a reputable dealer there are many counterfeits out there.
There are some videos showing you the difference between a counterfeit and the real Bosch.
duckrazee, Trevor Sawyer liked this post
08-16-2021, 12:34 PM #55
08-16-2021, 03:38 PM #56
08-22-2021, 01:37 PM #57
Any recommendations on where to locate a fuel pump? Summit has sent me the wrong one twice now.
08-22-2021, 04:39 PM #58Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
Put it somewhere it won’t get wet. It’s a good idea to use a fuel pump relay. I would suggest somewhere close to the tank so it doesn’t have a long ways to pull the fuel.
stoker2001 liked this post
08-22-2021, 08:58 PM #59
Should have been more specific. I was referring to a location to purchase one. I'm tired of messing with Summit.
08-23-2021, 08:03 AM #60Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,743
- 377
- 2935
- 5185
Did you try Jegs? Forget that I did not see Bosch on the Jegs web site. Try Bosch headquarters maybe they can give you a local distributor.
Mirage Jag Setup?
By OntarioStreamin in forum Props, Setup, and RiggingReplies: 20Last Post: 11-07-2013, 09:56 AM -
mirage jag setup?
By superryan in forum Props, Setup, and RiggingReplies: 18Last Post: 03-10-2012, 02:59 PM -
90 mirage 2.5 200, setup
By @quaholik in forum Props, Setup, and RiggingReplies: 11Last Post: 09-14-2011, 05:20 PM -
Mirage Setup
By Peter J in forum Props, Setup, and RiggingReplies: 13Last Post: 11-26-2008, 11:19 AM -
Setup for Mirage ???
By Mirage in forum Props, Setup, and RiggingReplies: 1Last Post: 12-06-2001, 01:33 PM
