Results 1 to 4 of 4
    Jun 2021
    Yamaha 2T mid to high speed surge
    Hello all I'm new here, I'm a DIY "tech" I'm having some trouble in resolving a mid to high speed surge that I believe to be cylinder 5 intermittently firing on an 1985 Yamaha 150 v6 on a bass boat, I believe its cylinder 5 due the the visual condition of the spark plug, the plug is appearing mostly clean and wet(with gas) with a dark electrode porcelain and ground strap, where as all others are brown. the water pump was new 2 years ago and never overheated. this is what iv done/checked so far (not in order)
    • Compression tested, hot engine & cold - all 110 psi (all within 2% of each other)
    • Rebuilt fuel pump (minus the stainless steel one way valves)
    • Pressure and vacuum tested fuel pumps
    • Tested fuel pump pressure and vacuum at WOT
    • Set timing pointer and initial and advance with a dial indicator as per manual, checked with light to confirm
    • Rebuilt carbs and set float height per spec in manual
    • Replace the Yamaha control unit due to strange ohm readings
    • Replace the spark plugs
    • Resistance tested the entire ignition system
    • Replaced 2 ignition coils due to failing resistance test
    • DVA tested the entire ignition system at idle and @1500 rpm on ear muffs (I know no load but didn't have a 2nd person to drive well testing under load)
    • Replace the primer bulb and all the fuel lines and connectors and checked the tank pick up tube for obstructions (also tested with a new aux tank)
    • Installed a brand new ignition coil onto cylinder 5
    • Tested underway in water with the green wires disconnected from the rectifier/regulator
    Items I have Not yet checked and possible causes?
    • Reed valves
    • Cylinder head warpage
    • Cylinder head crack
    • Cylinder crack
    • Crank shaft cylinder seal ring???
    Would a hair line crack in the cylinder head or cylinder be enough to suck water through and cause a misfire but not show up on a compression test? I feel like this is an issue due to over fueling of cylinder 5 or ignition miss fire that is happing intermittently under load as the spark plug looked washed clean and some of the piston top as well, however I have not been successful in finding any evidence of water in the cylinder, plug looks wet an looks and smells wet of fuel I have picture of the plugs I can post as well as DVA test results that all exceeded the spec in my service manual.
    Jun 2021
    I was doing some spark gap jump testing with an adjustable unit and what I found was cylinder 3 was struggling(intermittently) to jump a 5/16" gap where all the rest would do it just fine, I'm thinking that under cylinder pressure this is where the misfire is coming from, after swapping a new coil to that cylinder and it continuing to misfire I was trying to isolate the problem to either the cdi unit or the trigger. not knowing which trigger fires cylinder 3 I began to remove one trigger wire at a time and retest hoping to find the one that would totally kill spark on cyl 3, however I found that it seem to stay intermittent through all the wires until I reach the last wire, white with red trace. to my surprise when I removed the wire/red trace trigger wire the spark on cyl 3 became very strong and would easily jump the 5/16 gap, this left me with more questions then answer as I did not get the test results I was expecting.. how is cyl 3 spark better after disconnecting a trigger? the cdi shorted internally or somehow that trigger being bad dragging down output and back feeding through the other trigger wire? the system has 3 triggers 2 wires on each.
    Jun 2021
    Does anyone know which trigger wire fires which cylinder? there are 3 triggers(pulsar coils) 2 wires on each trigger, each trigger can fire 2 cylinders independently by the cdi sensing which flywheel pole (north or south) passes that trigger first, ie north pole passes trigger 1 first signals cdi to fire cylinder 1, south pole swings pass it next it fires cylinder 2
    Jun 2021
    does anybody have an idea? I'm leaning towards the CDI as the triggers are pretty simple devices and I would think it be weak on 2 cylinders if a trigger was at fault.
  1. Low Speed/high speed or Idle stabilizer
    By floater88 in forum Technical Discussion
    Last Post: 04-18-2021, 06:41 AM
  2. remooving low speed/high speed spark advence module
    By jmr112 in forum Technical Discussion
    Last Post: 12-14-2016, 10:46 PM
  3. Makita high speed buffer, variable speed
    By BUD in forum Non-Marine Items
    Last Post: 10-10-2015, 01:22 PM
  4. New Yamaha high speed gear case.
    By Steve Austin in forum General Boating Discussion
    Last Post: 01-22-2003, 04:31 AM
