Results 1 to 10 of 10
    35 Post(s)
    Sport E vs Sport G
    Did these classes ever run together? Were the Sport E (OMC 3 cyl) racers just as fast as the Sport G (Merc 4 cyl) racers? Did any of the Sport E guys ever "step up" to run Sport G?
  2. Likes Mark75H liked this post
    Feb 2008
    Lake of the Ozarks and Stuart, Florida
    Well..in the UIM Offshore 3 / E class was always faster than the H class using Merc 4 cyl 80/85 HP.
    Yes..thats me in the E-99 Piraya/Evinrude 65 HP passing the H-24 Joker/Merc cyl 80/85 HP.
    The year is 1973.
    A Merc 650 3 cyl on the same boat (Joker #24) was also faster than the heavier and pretty slow Merc cyl 80/85 HP.
  4. Likes Jimboat liked this post
  5. #3
    Feb 2008
    This is from Roslagloppet Offshore Race 1975..by far the largest Offshore race in Scandinavia.
    The E class winner was Lars Ström/Christer Helin Piraya/Evinrude 75HP.
    Average speed over around 125 miles was 49,8 Knots
    1.7 Knots faster than the:
    H class winner Jukka Huutanen/Matti Valkoinen Argo/Merc 4 cyl 80/85 HP 48.1 Knots
    H-class Argo/Merc 80/85 4cyl.
    Attached Thumbnails Attached Thumbnails Rosis 1975 result..jpg   skanna0094.jpg   h class Merc 80-85HP.jpg
    35 Post(s)
    OMC Sport E Power Trim
    Quote Originally Posted by lars strom View Post
    I noticed that the OMC SE engines have bungees arounnd their mid sections. Was the power trim OEM stock?
  7. Likes lars strom liked this post
    Feb 2008
    Quote Originally Posted by WaterZebra View Post
    Well..Yes, for my E-class Piraya 17 I deleted the powertrim/pump to save weight and used a trim tank instead.
    (My own design in the yellow circle, close to 50 years ago)
    Of course you needed a powertrim for the SE class Clerici cat.
  9. Likes Jimboat, Instigator liked this post
  10. #6
    South Florida
    11 Post(s)
    Lars. Great minds think alike. I had exactly the same setup on my SE marathon boat.
  11. Thanks lars strom thanked for this post
  12. #7
    Feb 2008
    @2us70
    Well..Thanks..its way harder to make a boat in a smaller class to go fast..and weight is a big part of that.
  13. #8
    South Florida
    11 Post(s)
    I sealed off a couple of feet of the hull and deck at the bow to be the tank. Having the water weight at the very bow allowed trim effect using less water weight. The ballast tank also let me plane off with a 3 hour fuel load in the boat.
  14. Thanks Instigator thanked for this post
    Likes Instigator, lars strom, Mark75H, loop liked this post
  15. #9
    35 Post(s)
    Trim Tank / Ballast
    Weren't trim ballast tanks eventually banned from APBA / UIM? Or were the rules changed where you had to make min weight with these tanks empty? I know that S&F members are still using these set ups on their own non racing rigs and the tournament ski boat builders use "gunnel bags" for bigger low speed wakes for wakeboard jumping. Always thought that your own method of picking up water for engine cooling (pitot tube or prop blast) should have been allowed rather than relying on stock water pump inlets and impellers. The world record OMC V8 project ended up using prop blast pitot tube pick up just like the K&B gas model outboards use.
  16. #10
    South Florida
    11 Post(s)
    Every once in a while somebody would get caught using a auxiliary water pickup. This allowed running the motor higher than it could pick up enough water naturally to cool the engine. If you had the right prop you could run the motor high enough that it could not make enough water pressure to reach the top of the motor. The inline 6s had a problem with this. The inline 4s not so much.
  1. sport jet
    By tlwjkw in forum Engines Wanted
    Last Post: 01-13-2020, 02:24 PM
  2. 175 sport jet and 210 sport jet Difference?
    By Fishbum in forum Technical Discussion
    Last Post: 11-08-2015, 07:57 PM
  3. sport C
    By CALVIN in forum General Boating Discussion
    Last Post: 04-13-2006, 06:08 PM
