Results 1 to 10 of 10
06-24-2021, 11:35 AM #15000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
Mercury 3.ol lowers l&r bobs not sportys 1.75 sm. Shaft 5200$
LOW WATER PICK UP BOBS MACHINE SHOP DUAL HOSE FACTORY MERCURY LOWER UNITS.... END OF SEASON BLOWOUT SALE 4000$ BOTH LOWER UNITS LEFT AND RIGHT.
these lowers will fit 225, 250, 300 promax and 300xs 3.0 liter motors. 20" or 25" d.shaft.
20" stubby drive shafts, can easily be converted into 25" shafts (included). small shaft prop shafts, 1.75 gear ratio. I ran these lowers for several years on my boat until got 1.62 gears. They are fleetmasters with Bob's LWP. no salt fresh water lowers. They have been garaged for the last several years I'm sure prop seals and water pumps should be replaced. they have been exellent with 0 issues. bobs machine shop does a supurb job welding their nose cones on...full circle weld all around the nosecone. Bryan 703 501 8708 virginia.
06-24-2021, 11:46 AM #25000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
[I]$5200
they are Bob's big foot twin hose.
The torquemaster lower unit is made for higher prop setting than the fleetmaster, but you can plug the two upper holes to keep water pressure. Fleetmaster or Torquemaster is the way to go over a sportmaster as long your speed is below 85 mph.Apr 7, 2004
Re: Torquemaster Vs. Sportmaster (birdman)
The FLEETMASTER is absolutely identical to the Torquemaster, EXCEPT that it does not have the cast-in torque tab on the Starboard side of the skeg.
The FLEETMASTER is designed for "multi-engine boats", primarily but also can be found on many single engine outboards.
BOBS NOSE CONE TEST ON A 2.5 BASS BOAT
NOSE CONES TESTED TOP-SPEED M.P.H. MAXIMUM MOTOR-HEIGHT
OBTAINED ABOVE TRANSOM WHILE MAINTAINING 10 PSI WATER PRESSURE MINIMUMR.P.M. OBTAINED WITHOUT PROP SLIPPAGE BOB’S 74.8 Sky High 6250 HYDRO MOTIVE 72.5 3-1/2 inches 6150 LAND & SEA 70.1 2-1/4 inches 5850 MERCURY STOCK 69.7 2-1/2 inches 5900 MERCURY CLS (RACING) 68.5 No limit 6150 REMEMBER: THE TRUTH IS AN UNDENIABLE FACT.
- 50% more cooling capacity with 5 inlet holes
- Higher speed & proper water pressure, superior quality
- Low water pick-up raising your motor with less drag
- 50% more volume than any now on the market.
- Nose cone kit contains all hardware for complete installation
- Kit comes complete with ALMAG-35 top grade casting, epoxy, hose fittings and instructions.
- Crescent shaped for superior speed and handling
- Five inlets create less chance of stoppage than anything now on the market.
"GO SHALLOW GO FAST"
make America great againLast edited by SUNKIST; 11-24-2021 at 09:23 PM.
10-04-2021, 06:35 PM #3Junior Member
- Oct 2021
- Orlando, FL
- 10
Some good info right there.
09-07-2022, 07:30 AM #45000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
end of the year blow out sale 4000$
09-08-2022, 09:50 PM #5
Will these fit a 1997 250xl? it's got a sportmaster now and it is a 3.0. I would bo interested in both if still available with 25" shafts.
09-09-2022, 06:24 AM #65000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
yes will fit your motor. send me your phone no. and shipping address
09-09-2022, 04:46 PM #7
Wondering if these will be OK on a lighter boat that runs over 90mph
09-10-2022, 11:26 AM #85000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
Yes, same as sportmaster but with larger and more water intakes 3 liter only.
04-24-2023, 09:26 AM #95000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
left and right low water pickup 3 liter 4000$
05-29-2023, 11:53 AM #105000 RPM
- Aug 2006
- virginia
- 662
- 39
- 63
- 277
- 725
Deposit recieved pending sale.
2 Mercury CLE Lowers
By Radiant in forum Lower UnitsReplies: 7Last Post: 06-05-2020, 03:08 PM -
mercury sei with bobs cone and swep skeg - low hrs broke prop shaft
By cptunnel in forum Lower UnitsReplies: 0Last Post: 05-13-2015, 08:58 AM
