Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
  1. #31
    Jan 2020
    Pinole, Ca
    You don't have water in the cylinders. Some look like they just aint firing
  2. #32
    Jan 2020
    Pinole, Ca
    And it sounds horrible in the video. Make sure your trigger leads on the switchbox are all correct like bob said. If they are in the wrong place they will fire but out of time so they won't run...
  3. #33
    Jun 2021
    Syracuse NY
    Piston wash photos
    Still no luck troubleshooting the ignition system so I decided to use a scope and take some pictures of the piston wash.
    Below are 2 photos of each cylinder in this order 1,1,3,3,5,5,2,2,4,4,6,6
    The 2 that sparked my interest are 2 and 6 I have short vides of them at the following links
    https://drive.google.com/file/d/175j...ew?usp=sharing
    https://drive.google.com/file/d/1tmV...ew?usp=sharing
    Anything to be learned from these? Please fire away.
    Attached Thumbnails Attached Thumbnails 210716_142338[1].jpg   210716_142344[1].jpg   210716_142444[1].jpg   210716_142449[1].jpg   210716_142524[1].jpg
    210716_142532[1].jpg   210716_142610[1].jpg   210716_142615[1].jpg   210716_142820[1].jpg   210716_142832[1].jpg
  4. #34
    Jun 2021
    Syracuse NY
    Its fixed. Humbled to say the final fix came about with 6 New Spark plugs. I was seeing spark on all cylinders with induction and gap testers but it didn't seem as though all cylinders were firing. I removed all the sparkplugs attached their wires zip tied each sides spark plugs together and grounded each bundle. When I cranked it over only 2 of the plugs had good spark. Thought I had replaced them last fall when I strted my troubleshooting, now not so sure.
    Thanks everyone who offered their ideas.
  5. #35
    Apr 2017
    pa
    5 Post(s)
    sometimes we overlook the easy stuff. Glad you got it fixed!!
  6. #36
    Jun 2021
    Syracuse NY
    Took the boat out today and engine ran great. Was a running a little hot in no wake zone and a little cool when opened up. I plan on replacing the impeller as there was some dry cranking during my repairs. Got back to the ramp idled in tach started acting funny and it stalled when I took it out of gear. Was hard to restart then it cut out and smoke starts pouring out of the engine. Rectifier is melted. Few questions. Is this likely to have damaged any other components? What should I check before replacing rectifier? I have a new cdi 40 amp stator 174-9610K that has 2 yellow and 2 yellow/black wires and jumpers that pair them together for the 2 wire rectifier. Can I replace the single rectifier with the dual 20 amp rectifier 194-8736?
  1. Mariner Magnum II 150 - wont run in gear over a idle RPM speed
    By everyoneknowsjeff in forum Technical Discussion
    Last Post: 05-20-2013, 09:03 PM
  2. Mercury Tech: 1989 25' searay losing speed
    By cathken in forum Technical Discussion
    Last Post: 09-06-2009, 09:12 AM
  3. My searay jetboat wont start
    By peterpaul in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 06-25-2009, 10:19 AM
  4. Merc 175 EFI wont idle...? Just dies...
    By Bartman39 in forum Technical Discussion
    Last Post: 08-19-2007, 07:23 PM
  5. 115 merc wont idle
    By VectorPat in forum Technical Discussion
    Last Post: 07-07-2002, 03:19 PM
