Results 1 to 15 of 20
Thread: Best fiberglass rollers?
06-21-2021, 11:35 AM #1
Now that we're getting the hang of rolling the bubbles out of the 1708 Im noticing my rollers seem crap. We clean them very well but they squeak and tend to hang up here and there not always rolling sometimes skidding which i dont like at all. Is this just the way these things are or are there some brands to buy that work better? I searched quite a bit and didnt really find which brands or maker that stood out as the best way to go.
caymanpowerboats liked this post
06-21-2021, 11:59 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Get the ones that have a screw at the end so you can take the thing apart and clean it. Deep fins are better. Alum. rollers only, so you can wire brush them. I have rollers that I have used for 20 + yrs. And like everything else, they don't make em like they used too.
06-21-2021, 12:05 PM #3
agree i also have rollers 20-40yrs old
and rolling structure material like 1708 want larger diameter rollers so resin dont get into the shaft
and deep finned as stated dont want prickly rollers to grab the weave
06-21-2021, 12:14 PM #4
I have the take apart kind, all aluminum with a plastic handle. I did buy a spiked one ( prickly ) that I havent used yet that rolls soooo smooth. It appears to be bushed with brass or bronze it just seems to roll so much better. I'll buy another deep fin one and see how it goes. The one I seem to use the most is 3"w about 3/4" dia.
06-21-2021, 12:47 PM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The pricky ones are for veil mat and .75 oz mat used for the "skin" out. Which is the 1st layer on a mold.
LakeFever thanked for this post
06-21-2021, 04:54 PM #6
Built here in Winter Haven and were always great products.
https://www.bodico.com/
LakeFever thanked for this postXstreamVking, CUDA liked this post
09-03-2021, 05:56 AM #7Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3030
- 5316
The rollers I have are made out of some type of composite material. The rollers are attached to a metal rod. When I’m done I soak in acetone, using it for 20 years never had a problem with it hanging up.
LakeFever liked this post
09-03-2021, 06:41 AM #8
^ solid info thanks! I never did order any good ones I switched it up during application instead of brushes to 4” mini paint rollers ( whizz rollers ) and those are now my goto method along with the finned rollers that I have to finish it up. Much less fin rolling required so I’m not as frustrated with the squeaky ones I have now. If I do another resto I will find these composite ones you mention, that sounds perfect. I even thought about drilling the center of mine out and adding a Teflon sleeve bushing but that would take a lot of time I don’t need to waste on this now while the hull build is going solidly forward.
09-03-2021, 07:17 AM #9Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I preferred the metal ones. Never used to worry about cleaning them well when done. Just lit them on fire and burned them clean. Wire wheeled them (spin fast) after that and they roll like they have bearings. Swish them in acetone to flush the soot and perfect. Still have about 20 of all shapes and sizes. From 18'' x1'' to 3''x 1/4''. Also round wheels for radius rolling, and football shaped for interior curves.
09-03-2021, 07:18 AM #10Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3030
- 5316
09-03-2021, 07:51 AM #11Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I have some of them too. I had to take them apart and clean them everytime I used them. They are nice tho.
09-03-2021, 08:16 AM #12
I only have four, and three are flat, one ball. I could use a bunch of different shapes but I have managed through this build fortunately although it has been a struggle at times. Sometimes I use my hands with gloves and can squeegee the glass down a bit. Messy as hell but it worked
09-03-2021, 08:35 AM #13
you can also use a torch to get rid of the hard resin if it kicks quick. take the roller off and burn it off.
1973 Viper - sold
1978 Viking - sold
1995 XB02
09-03-2021, 11:07 AM #14Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3030
- 5316
10-30-2021, 05:26 PM #15
OMC Tech: Different cams and rollers
By Captain75 in forum Technical DiscussionReplies: 12Last Post: 04-17-2017, 12:35 PM -
rollers or bunks
By PHISH in forum General Boating DiscussionReplies: 11Last Post: 05-15-2006, 09:41 PM -
trailering/ ROLLERS OR BUNKS
By advantage87 in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 01-05-2005, 09:08 PM
