Results 16 to 21 of 21
07-23-2021, 05:33 AM #16Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Oh, hell. Never mind.....Just carry on burping bubbles.
07-23-2021, 08:42 AM #17
It is interesting to see all the difference approaches to this. The method I listed is essentially the same as any loader or hydraulic machinery that has a dump tank. This set up is completely self bleeding. Only difference with these steering systems is they are closed loop. Once the self bleeding is done, close the bleeders, done. Line orientation or routing doesn’t matter.
as for the setting valves I had no idea that’s something new I learned today thanksHydrostream dreamin
07-23-2021, 10:28 AM #185000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
I don't have the patience. 30 minute labor for someone with a power bleeder is well worth it to me.
ANTI40It's just an idea.
powerabout liked this post
07-23-2021, 12:32 PM #19
I have a power bleeder, doesnt work on this system very well. The challenge is it switches direction in the same network. Most hydraulics are only in/out where these are flow left/right in a closed loop. A power bleeders struggles to get the center point bled properly where the tank style allows the system to remain wet for 100% of the switching and it does get out all the air. It took me 2 mins to use a razor knife and cut the bottom out of a 1 quart seastar fluid jug. I used the nipple adapter in my seastar kit on the bottle and the helm and I bought the clear line same size as supplied in the kit but I bought a 20' roll at Home depot. I used a forged eye with 3/8" threaded pedestal to drop the upside down seastar bottle into taped to a ladder in the air about 7' high and ran the 10' lengths of clear hose from the bleeders attached with tie wraps around the bleeder nipples then routed up to the top ( cut bottom ) of the seastar jug INTO THE FLUID. The ends of the lines have to be submerged into the fluid or this will not work. Cranked both bleeders open and then turned the wheel for 5 mins or so per side to get out all the air. That was it
First time I did this the steering was responsive but I noticed the wheel clocking changed as I was driving so I wondered and approached bleeding it again. When i first started bleeding I had one air bubble about the size of a pea come up but one side only. While I was bleeding I realized the more I clocked the helm around that I could see very tiny bubbles starting to come up the lines. So I locked it all down and did the next day trick and now the wheel will not turn past lock no matter how hard I try. Im a big dude and I cranked on that wheel, its bricked tight.
Since then driving has been butter. The only thing I dont like about the seastar is the clicking sound the helm makes when changing directions. Its a minor issue but it does bug me a little.Hydrostream dreamin
07-23-2021, 12:57 PM #205000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
07-23-2021, 01:03 PM #21
Hydraulic steering problem
By largecar91 in forum Technical DiscussionReplies: 22Last Post: 04-02-2018, 07:18 AM -
Hydraulic Steering Problem
By Scott Tharpe in forum Technical DiscussionReplies: 10Last Post: 05-04-2010, 08:45 AM -
By quicktrip in forum Technical DiscussionReplies: 1Last Post: 05-24-2008, 02:57 PM -
Help - Hydraulic Steering Problem
By Air Dog in forum Technical DiscussionReplies: 3Last Post: 05-20-2003, 03:35 PM
