Results 1 to 7 of 7
    Jun 2021
    lakeland fl
    MERCURY 225 efi DRIVESHAFT HOUSING
    2001 mercury 225 efi 3.0, I only need to replace the "lower" exhaust plate gasket can I just remove the foot and drop down the driveshaft housing and not remove the power head?
    ...welcome to scream & fly...
    Nope .. 4) 8mm you have to remove.
    Ft. Lauderdale, Fl
    Being a 2001, changing all the mid section gaskets is a good idea........... And as Chaz said..... nope, it has to come apart from the top down. Plus, the powerhead studs go down through the housing.
    Jun 2021
    lakeland fl
    I had the power head off and replaced the motor mounts and upper and lower exhaust gasket but when I put it back together had no water to the heads. Removed the power head and found I was sold the wrong gasket so I replaced it again. Reassembled still no water will go up to the heads even with a water hose directly on the water pump tube running up. All I can guess is somehow the lower gasket is also blocking it? Thank you very much for the input,
    Quote Originally Posted by jgo5099 View Post
    Fiddy-99 ,
    This is the correct lower gasket ..
    https://parts.promarineusa.com/produ...M50/1/1/27-831
    This is the correct powerhead base gasket ...
    https://parts.promarineusa.com/produ...M50/1/1/27-832
    If you have the above correct .. then chances are pretty good the inner seat is goobered up or the diaphragm is torn ..
    https://parts.promarineusa.com/produ...0/1/1/POPKIT30
    Jun 2021
    lakeland fl
    Sorry for the delay almost gave up on the motor and parked it. I have since has Chris Carson rebuild the powerhead and change the water impeller. My alarm still goes off after running it about 3 - 5 min and it goes into limp mode. The head temp is only 164 and I changed the water temp sensor,
  1. Mercury 2.4l driveshaft housing 20" nla
    By Cal 47 in forum Misc. Parts and Accessories
    Last Post: 03-17-2015, 08:07 AM
  2. Mercury / mariner 2.5 driveshaft housing 20"
    Last Post: 03-17-2015, 08:00 AM
