Results 1 to 15 of 21
    Oct 2018
    TX
    20XD Bullet---250R Setup
    I just hung a new 250R on my 20XD and have serious control issues. Once up and running the ass end is all over the place and the steering feels like there isn't anything there. I started out about 1/2 inch above the pad and dropped it down to 1 inch below the pad. I did get more lift but the ass doesn't feel "Planted". This isn't my first Bullet and actually the 4th motor on this hull and none of the previous motors were so hard to get set up. Wondering if anyone running the same rig can share their setup?
    20XD, 250R w SM lower, 29 Bravo1XS (Had cup added), 12 inch Bob's Hyd plate with 2 inch spacers.
    Thanks In Advance!
    Jan 2020
    Pinole, Ca
    Out of curiosity, what steering are you running?
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    ...and is it the same steering as the previous engine?
  4. Likes 25two.stroke liked this post
    Oct 2018
    TX
    Seastar Hyd and yes it is the same as previous
    Feb 2017
    Wixom lake michigan
    I know nothing about your setup, but im guessing remove the spacers and raise the engine. Someone will come along and confirm, but i believe some are finding less setback is necessary with the v8. Also 2 of my boats have felt as you described when propshaft ks too low. Again, no expert here, just a guess.
  7. Thanks JBS thanked for this post
    Oct 2018
    TX
    Changed to the "Required" Seastar steering cylinder. Removed 2 inch spacers. Dropped the motor down a hole (I have Hyd Jackplate). Handling issues solved. Much more stable. Now to get it propped right. I run a 29P Bravo1 XS that has a great holshot and mid range but due to high slip (19%--20%) just not getting the top speed it should. Waiting on responses from Merc Racing and Spinelli on pitch recommendation on Max5 ST and DR5 props!
    Feb 2017
    Wixom lake michigan
    Excellent, glad to hear you are getting her dialed
    Oct 2018
    Tennessee
    Just curious, do you have a transducer mounted and where is it located?
    (Rip. Whiteally02) -dad
    May 2016
    keys
    Did you make all those changes at once? Or incrementally to see which change actually made the most difference?
    ANTI40​It's just an idea.
    Jul 2021
    Pompano Beach
    At your speed, I think a Pro-Max would be a better prop and get you the speed you're looking for than the Bravo 1 XS. Probably will need to up pitch as the promax is a 14.5" diameter prop.
    Oct 2018
    TX
    Tried a 29P ProMax--Did not work at all--Starts out like a freight train then completely blows out before the nose breaks over.
  14. #12
    Houston, TX
    You ever tried a four blade hydromotive with extra cup? Carries that boat nicely and is drivable.
  15. Likes Hydrodreams liked this post
  16. #13
    Oct 2018
    TX
    Quote Originally Posted by rgsauger View Post
    Yes I have same outcome
  17. #14
    Oct 2018
    Tennessee
    My buddy is running a 25 fury on his 250r, he had a250 pro xs, with a 27 fury but actually had to downsize to the 25 for better performance
  18. #15
    Oct 2018
    TX
    I currently run a 29P Bravo---I don't think a 25 will be near enough!
  1. 250R on Bullet 20XDC Need set up help
    By owenssw in forum Props, Setup, and Rigging
    Last Post: 06-18-2021, 12:10 PM
  2. Bullet 20xd w 225 pro max
    By Fear And Loathing in forum Hulls up to 20'
    Last Post: 09-01-2014, 02:27 PM
  3. Bullet 20xd setup
    By JTSTV in forum Props, Setup, and Rigging
    Last Post: 10-11-2013, 08:04 AM
  4. Bullet 20Xd with a 280
    By TEXAS20225 in forum Props, Setup, and Rigging
    Last Post: 04-05-2012, 11:07 PM
