Results 1 to 4 of 4
    Jun 2011
    Hvaler, Norway
    Question 1994 Evinrude 225 VRO/FUEL PUMP PROBLEM
    Hi,
    I have just bought a 1994 Evinrude 225 that has been sitting for a while.
    Previously I have only experience with Merc and does not know the VRO pump and how it works...
    Everythig is hooked up inkl. the oil tank and wire connections.
    The engine does not start (I have flushed the carbs) but it looks like no fuel are going through to the cylinders.
    It has spark on all plugs (but not the best spark i have seen...).
    Do you need a electric fuel pump to prime the VRO?
    I hooked up a 5psi pump today for testing but this made the carbs overflow and also some leakage from the VRO pump so probably not the best thing to do
    Any suggestions or ideas are highly appreciated
    Thanks,
    Lars
    Lars P Helminsen
    Hvaler Islands, Norway
    Birchwood 29 / Evinrude 225 - Pleasure project
    Moore F2 / Merc 200XS SST - UIM F2
    Seebold F2 / Merc SST120 - UIM F2 - Sold
    Lustcat 18 cat / Merc XR2 - Sold
    Hydrolift CR24 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
    Argo 22 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
    Argo 21 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
    Hurrycane 470 v-bottom / Merc 115 In-line 6 - Sold
    Hurrycane 370 v-bottom / Yamaha 30 - Sold
    Ft. Lauderdale, Fl
    If the carbs are overflowing with 5 pis of pressure, you need to rebuild them with new needles and seats. As for cranking and spark, you need a good, strong battery 800CCA or better to get at least 300 rpm in cranking to get good spark. If the VRO pump is leaking, time to rebuild it, replace it or eliminate it and either installing the fuel pump setup from a commercial version of the engine or going with and external electric pump and pre-mixing the fuel.
    Jun 2011
    Hvaler, Norway
    Thanks for the information @flabum1017
    I will go through it today checking the VRO pump and replace all fuel and vacuum lines and also get a new battery to test.
    Regarding fuel pressure from an external fuel/lift pump, I have read that the VRO and or carbs only can handle 3-4 psi without overflowing the carbs but is this not right?
    Jun 2011
    Hvaler, Norway
    Got it started yesterday and it runs quite nice
    The spline on the flywheel was gone so the ignition was way off.
    Lars P Helminsen
  1. OMC Tech: evinrude v8 VRO fuel pump conversion to two fuel pumps
    By alexvzx in forum Technical Discussion
    Last Post: 09-07-2018, 01:31 AM
  2. Mercury Tech: Pro Max ECU/fuel pump Problem
    By Go Time in forum Technical Discussion
    Last Post: 04-18-2012, 08:55 AM
  3. 1994 Yamaha 250 V76 fuel problem.
    By Tom Smyth in forum Technical Discussion
    Last Post: 06-12-2011, 05:43 PM
  4. fuel problem?? 93' 225 evinrude
    By Big Rude in forum Technical Discussion
    Last Post: 04-18-2009, 06:10 PM
  5. evinrude fuel problem
    By STEVEDRACER in forum Technical Discussion
    Last Post: 09-01-2008, 10:51 PM
