Results 1 to 11 of 11
Thread: wtb fuel pump 90 2.5 200hp carb
06-15-2021, 05:00 PM #15000 RPM
- Oct 2013
- east tennesse
- 198
- 10
- 9
looking for fuel pump 1990 mercury 2.5 200hp
or what electric pump for 200hp carb 2.5l
got this engine they removed oil pump and fuel pump, so need help?
thanks chris
06-15-2021, 05:11 PM #2
Easy to put the factory pump back on, I have one if you need it. Send pics of what you have on the engine now so I/we know how much you need. You can go with a holley red or mighty mite with an external adjustable reg set at 4psi if you want.
06-17-2021, 07:55 AM #3
original pulse pump will supply all the fuel you will ever need. electric pump would serve no benefit.
25two.stroke liked this post
06-17-2021, 11:40 AM #45000 RPM
- Oct 2013
- east tennesse
- 198
- 10
- 9
06-17-2021, 11:50 AM #5
I have dozens of them, as I'm sure other people on here do also. Probably cost $100 for an OEM. Get used one off of 25twostroke since he offered. I would also buy the oil pump block off kit. yours is just capped off. you need the dipstick style. holds bushing in place and stuffs the crankcase a little. I will post a pic.
06-17-2021, 11:53 AM #6
06-17-2021, 11:55 AM #7
The previous owner might have left gear in there also. just pull it out and replace with dipstick
06-17-2021, 11:59 AM #85000 RPM
- Oct 2013
- east tennesse
- 198
- 10
- 9
06-17-2021, 12:07 PM #9
WTH is the brown thing right below where fuel pump mounts?
06-17-2021, 12:39 PM #105000 RPM
- Oct 2013
- east tennesse
- 198
- 10
- 9
looks like clamp to me, i think it hold a filter or reg, and pres. gauge not that way i like to go. need pulse pump or part number thanks
06-17-2021, 12:42 PM #11
Looks like a copper ring or somethin...I was wondering that. Yeah buy the proper oil inj. plug
Fuel pump p/n 14360a78 Yeah I have them around but probably can't get to the shop to find one till Saturday. If you still need one by then call me 510-418-4911 and I will get one and flat rate ship it to you. Or if someone else has one sooner then grab that up
Mercury Tech: 1991 200hp, which electric fuel pump to use
By nacimientobound in forum Technical DiscussionReplies: 6Last Post: 07-26-2014, 02:13 PM -
Fuel pump for carb motor?
By 97 TWISTER in forum Technical DiscussionReplies: 14Last Post: 06-17-2012, 11:09 AM -
Fuel pump for Merc 200HP EFI
By shooter1 in forum Technical DiscussionReplies: 1Last Post: 04-04-2006, 08:33 PM -
Going From Carb To Efi Fuel Pump Question?
By JASON ALLEN in forum Technical DiscussionReplies: 4Last Post: 03-03-2005, 10:15 PM
