Results 1 to 4 of 4
Thread: Jet boats like Sea Doo
06-13-2021, 09:16 PM #1
I boat in salt water that at times has sea weed. When I had my jetskis, you had to jump in the water and pull the eel grass out of the intakes if you ran into a patch of it. With Sea Doo and yamaha jet boats, do you have to do the same thing or is there cleanouts inside the engine hatch? Thanks, MIke
06-13-2021, 09:43 PM #2
Some of the newer SeaDoo boats have the "weedless system" but there is no way of accessing the tunnel or grate from inside the boat. As far as I know all SeaDoo & Yamaha jet boats use the same grate, tunnel & pump design as the PWC's. RR
06-14-2021, 12:41 PM #36000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,238
- 55
- 300
- 2748
- 3879
I have the same problem in the Keys. Our SeaDoo has the reverse option on it and if we get sea grass sucked in we just put the machine is reverse mode and give the throttle 1 or 2 quick blips. The seagrass gets expelled most of the time, not always but most of time. If not, jump overboard and pull grass out with engine off for safety.
06-14-2021, 02:20 PM #4Member
- Aug 2018
- To far away from the lake
- 53
- 27
Last I knew Yamaha was the only one that you can unclog from the boat:
https://www.youtube.com/watch?v=2AbV2xGzASU
David - WI thanked for this postnoli liked this post
How many guy's on here have 2004-2005 boats or have older boats ??
By LPB in forum General Boating DiscussionReplies: 114Last Post: 01-13-2018, 06:09 PM -
Switzer boats? Any info on these boats?
By JoePA in forum General Boating DiscussionReplies: 13Last Post: 07-29-2011, 02:29 PM -
New mini performance boats? - St. Martin Power Boats
By jonnyspeed in forum General Boating DiscussionReplies: 11Last Post: 04-09-2009, 08:30 PM -
Bass and Walleye Boats Mag...Triton boats!
By Mr.Rude in forum General Boating DiscussionReplies: 5Last Post: 06-06-2006, 10:13 PM -
Triad Boats and STV Custom Race Boats
By Dinomite in forum General Boating DiscussionReplies: 16Last Post: 12-27-2003, 10:30 AM
