Results 1 to 5 of 5
    Oct 2003
    Albany NY
    1988 85 Force ignition
    Hello friends... I am trying to troubleshoot my friends 85 HP Force outboard. #1 cylinder has no spark. To make matters worse.. I can't remove the flywheel to inspect the stator. Is there something I can check without removing the wheel?
    I know you guys are the best! Thanks!
    Houston, TX
    Could you swap coils and see if it follows?
  3. Likes Forkin' Crazy liked this post
    Oct 2003
    Albany NY
    Problem stays with #1 cyl. I got the flywheel off finally! There is a circular type magnet... all the way around... not secured in any way! Stator coils look good but didn't check with meter
    Oct 2003
    Albany NY
    runs on #2 and #3. suspect stator... low resistance on one yellow wire, like 500 Ohm
    Aug 2009
    mpls,mn
    Thats one of the worst ing systems on the planet. The cdi boxes work together and will fight each other.Usually you will have to replace both cdi boxes and the stator. Could cost more then the motor is worth.Or find a set of electronics in working order on ebay/fb? Good luck bro you will need it.
  1. Air Force One? How about BOAT FORCE ONE!!! MAGA!!!
    By home made tunnel in forum General Boating Discussion
    Last Post: 09-29-2018, 11:10 PM
  2. Replies: 0
    Last Post: 04-07-2016, 08:08 PM
  3. 1988 Baja Force 216 - good boat?
    By puzzleboy in forum General Boating Discussion
    Last Post: 07-07-2009, 06:11 PM
