Results 1 to 10 of 10
Thread: Sneeze/cough at idle
06-12-2021, 10:31 AM #17000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
So I don't know if its a lean sneeze or something else. Motor is back up and running, its always has a cough at idle, itll be running fine then itll stutter and cough out a puff of smoke, if im in gear at idle it seems to do it and sometimes itll do it and stall out. It starts right back up, if I rev the motor up it seems to clear it up for a bit. Carbs are rebuilt and had CCMS reeds, runs perfect off idle.
06-12-2021, 02:08 PM #26000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
Sputter Cough Diagnosis
It might be caused by exhaust back pressure stacking up to a point where it interferes with combustion in the cylinders. A very quick way to eliminate this possible cause is to run it on a garden hose where there is no water backed up thru the exhaust system. If it idles forever without stuttering of coughing then the exhaust system isn't breathing the way should. Usually the mid section tower has ports where the exhaust has a shorter path to escape. The ports should be spitting out exhaust and cooling water. If not, then you probably have passages blocked by silt or salt.
06-12-2021, 04:54 PM #37000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
It does it on the hose and in the water.
06-12-2021, 06:01 PM #4
Lean spit.... might have to go a little smaller on your idle air jets.
Forkin' Crazy, keefallan liked this post
06-12-2021, 06:03 PM #5
First, do a sync and link..... carb sync is very important.....
Forkin' Crazy liked this post
06-12-2021, 09:03 PM #6
Do as said above, its very important that all 6 carb throttle plates are all closed at idle with a slight gap in the carb roller to throttle cam. a larger gap on the throttle cam will richen up the lowend.
06-13-2021, 05:51 AM #77000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ok. I'll look into that. Thanks
06-13-2021, 07:20 AM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Do the john rudes blow a fuel pump diaphragm when they sneeze like the mercs do?
06-13-2021, 08:13 AM #9
Newer stuff has a valve in the pulse fitting to help with this.
06-13-2021, 09:04 AM #10
They can blow composite reeds.
H2OPERF liked this post
Merc 225 efi cough at idle
By Seanj85 in forum Technical DiscussionReplies: 16Last Post: 09-28-2019, 02:40 PM -
Cough at Idle
By Blown Up in forum Technical DiscussionReplies: 0Last Post: 06-28-2017, 11:50 AM -
Merc 300 Sneeze/cough
By 300Procraft in forum Technical DiscussionReplies: 9Last Post: 02-13-2017, 07:08 PM -
Sneeze at idle
By Blown Up in forum Technical DiscussionReplies: 5Last Post: 04-29-2013, 09:22 PM -
motor sneeze's at idle
By themdshrk69 in forum Technical DiscussionReplies: 11Last Post: 01-20-2010, 09:50 PM
