Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    Jul 2005
    AZ
    And everything you've got there is photo worthy.
    In what ever stage etc all boats...hey not everything is a hydrostream..lol
    '84 Checkmate Convincor
    Twin v6 closed deck Evinrude loopers Ported,2.7 heads,cooling mods
    milled finger ported to match vertex pistons,
    All casting slag removed
    Sleeves in opposite so no idle reliefs
    Offshore exhaust mids
    152 psi comp,balanced pistons and rods,Stuffed, 106 pullovers
    CDI 8500 digital ignitions ..Boyesen reeds..And more..
  2. Likes 25two.stroke liked this post
  3. #17
    Los Angeles Cal.
    That's what I meant. Thats what I want to do with the hydrostream. I don't care if it only does 90 or so...I don't really want to build it for long delta runs, just short bursts after work when theres 2ft chop.
    Thats why I am building my 3ram trim 15" mid with the early EFI cowl and hoped up Bridgeport, hopefully I can keep it light.
    I will set the Mirage up for running the delta with Kevin, Rufus and the rest of the gang up there.
    Someday I need to get a larger prop like a 29 so when I do Delta runs I can keep the RPM down. The biggest prop I own is a 24 but I can spin it pretty good and get a decent top end. Most of the time I enjoy cruising around 40 to 50 miles an hour.
  4. #18
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by Stoker boy View Post
    Well when you come up you can run one of mine and/or take one home. I have a 26p 3 blade chopper, 27p drag 4, 27p Spinelli ET, 28p 3 blade chopper, and 25p TH cleaver...one of those ought to run good and keep your rpms down!
  5. #19
    Los Angeles Cal.
    Thanks.
  6. #20
    Jan 2020
    Pinole, Ca
    Made a double length transom saver cause factory ones are too short. Painted it pink cause why not. I also put in a smartcraft water pressure sender tonight, cause 150s dont come with them...
    1984 Hst VKing - stock Bridgeport EFI
    - 190psi Ovalport EFI
    25 hp Merc with OFFSHORE style midsection
    25 hp Merc with dry side pipe
  7. #21
    Los Angeles Cal.
    The transom saverís Iíve seen are adjustable. Long or short whatever is needed. I see a red strap but I really canít see the transom saver. Iím thinking about the type that goes from the trailer to the lower unit. I had one years ago it was called a gator graber.
  8. #22
    Jan 2020
    Pinole, Ca
    The transom saver’s I’ve seen are adjustable. Long or short whatever is needed. I see a red strap but I really can’t see the transom saver. I’m thinking about the type that goes from the trailer to the lower unit. I had one years ago it was called a gator graber.
    Yeah thats the one that I used as a core, but even though its adjustable it was too short...so I replaced the aluminum bar for a longer one. Thats what you see as a red strap...its not a strap its a steel bar.
  9. #23
    Jan 2020
    Pinole, Ca
    Built a fat shaft CLE on Saturday. Cut and re-splined driveshaft from CCMS...I like it. I want to strip the paint and polish it next.
    Notice the rise/run of the stair in the back of the shop, I'm sure its OSHA approved.
  10. #24
    Jan 2020
    Pinole, Ca
    Sunday I took the aquasport out to slay some halibuts...couldn't ask for a nicer day on the salty pond.
    Yeah, I like how the fourstroke trolls so quietly and the troll control is essential. Getting all the engine data and AIS on the Garmins is also just as essential when fishin in that thick of fog with no radar.
  11. #25
    Los Angeles Cal.
    You are part of the food chain out there.
  12. #26
    Jan 2020
    Pinole, Ca
    Definitely part of the food chain...especially when you can't see 1/4 mile. This weekend brought a tad nicer visibility, but the water was whooped in the middle of the tide. Like 6ft @ 5 sec.
    Running back home was nice though. Made it back early for father's day dinner.
    Attachment 489263
  1. you asked for it !!
    By superboat24michael in forum The Scream And Fly Lounge
    Last Post: 08-21-2010, 04:26 PM
  2. I'm sure this has been asked before
    By stealthdrummer in forum Fiberglass and Composites Discussion
    Last Post: 04-13-2010, 06:10 AM
  3. Story of my Life
    By Racemore in forum The Scream And Fly Lounge
    Last Post: 01-05-2008, 10:20 AM
  4. I know I have asked this before...
    By Dargo in forum Props, Setup, and Rigging
    Last Post: 11-10-2003, 03:41 PM
