Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Feb 2021
    Milwaukeeish
    I'm wondering if just adding joists between the tunnels, and tying those into the floor would work.
    There is no wood core in this boat, and sleeks are known for being heavy layups, but I would think that some force on the keel would be transmitted via the stringer into the floor. As far as I know the floor was bonded to the tops of the tunnels, so any pressure upwards would hit a wall of plywood about 2' wide that is glued down with resin onto the tunnels, and glassed over on to the sides of the tunnels.
  2. #17
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by ADDvanced View Post
    Somewhat, yes, but not as much as if it was adhered to the stringer at the top like it was at the bottom. When you say joists, do you mean full height? Keel to underside of floor?
  3. #18
    Feb 2021
    Milwaukeeish
    Yes. The thing had a few sets of joists bracing the stringer against the sides of the tunnels, all the way up to the bottom of the floor.
  1. Coosa Transom- (2) 3/4" sheets or (1) 1.5" sheet?
    By starviper10 in forum Fiberglass and Composites Discussion
    Last Post: 05-30-2015, 01:52 PM
  2. coosa
    By buzmacdowell in forum Fiberglass and Composites Discussion
    Last Post: 11-18-2012, 02:13 PM
  3. coosa,composit's
    By albypine in forum Fiberglass and Composites Discussion
    Last Post: 05-27-2011, 11:36 PM
  4. Coosa board
    By Ronny Jetmore in forum Fiberglass and Composites Discussion
    Last Post: 05-20-2009, 04:07 AM
  5. Coosa? Anyone?
    By tlwjkw in forum Fiberglass and Composites Discussion
    Last Post: 02-28-2007, 09:46 PM
