Results 46 to 60 of 63
Thread: 2.4 200 electrical gremlin
06-08-2021, 04:40 AM #46
06-08-2021, 05:13 AM #47
Disconnect the regs red wires and cap them off.
bullet123 liked this post
06-08-2021, 08:20 AM #48
Smalltownbassin liked this post
06-08-2021, 10:28 AM #49
06-08-2021, 10:33 AM #50
yes. falls off plane and bogs as you pump hotfoot. its not an engine problem. something is killing power source to the boat. if I was using a pulse pump im sure it would keep running.
25two.stroke liked this post
06-08-2021, 10:34 AM #51
im pretty sure its the hot wire going to ignition switch
06-08-2021, 10:37 AM #52
Running to many things on one circuit.
06-08-2021, 10:46 AM #53
that's what I thought at first, so I put electric fuel pump on a relay with its own ground. I would have thought if I had to much load on the hot wire it would blow the fuse. the bad part is..... im doing so many changes at once, now I wont know what I did to fix it.
06-08-2021, 10:48 AM #54
I was just going to say that,get it fixed and you wont know which one fixed it.
06-08-2021, 10:50 AM #55
fixed is fixed I guess.
06-08-2021, 10:53 AM #56
Have you spread the terminals on the eng harness from the boat and plugged it in the motor harness and then clamped it with a worm clamp?
06-08-2021, 10:57 AM #57
Never thought of that. you mean spread the male pins? Ive done that on efis
06-08-2021, 10:59 AM #58
Yes seen it many times before,wont do it in the driveway but when you go bouncing on the water they short out.
bullet123 thanked for this post
06-08-2021, 11:04 AM #59
good idea. thanks
06-08-2021, 11:08 AM #60
Even did that on my old mans bayliner I/o was only a few yrs old mercruiser kept dying out on the water put a clamp on it never did it again.
300R Gremlin
By RED ONE in forum Technical DiscussionReplies: 9Last Post: 03-19-2020, 01:24 AM -
Mercury Tech: Electrical Gremlin FYI
By vnemous in forum Technical DiscussionReplies: 0Last Post: 05-03-2017, 11:31 AM -
fat idle gremlin
By fortlaudypower in forum Technical DiscussionReplies: 1Last Post: 04-07-2016, 11:48 PM -
'95 200 XRi, electrical gremlin...I think...help needed
By silverbullet02 in forum Technical DiscussionReplies: 7Last Post: 06-23-2008, 12:18 AM
