Results 16 to 30 of 63
Thread: 2.4 200 electrical gremlin
06-07-2021, 08:38 AM #16Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10932
If it's an efi, it could be as simple as bad batt terminal and or cable connections to the engine. Or key switch. Sounds like when it wants more power there isn't enough to keep it running.
06-07-2021, 08:39 AM #17
works flawlessly until I give it power. seems like the higher output from stator is heating something up and making it lose connection
06-07-2021, 08:42 AM #18
I was thinking ign switch until trim on boat quit working at same time. is there a wire they all have in common? red fused wire? maybe hot wire splice on engine harness under tape? It is after fuse because trim at motor switch wont work without fuse
06-07-2021, 09:01 AM #19"The character of a man can be easily judged by how he treats those who can do nothing for him"
06-07-2021, 09:02 AM #20
XstreamVking thanked for this post
06-07-2021, 09:04 AM #21
Did it do this with 16amp system?
06-07-2021, 09:21 AM #22
Never tried 16 amp. I took a 2.4 200 rotating assy and converted it to a 2.5 cooling system and 40 amp charging system. Im going to tear engine harness apart or replace and try to find a ground that they all share. I was just hoping somebody on here had ran into something similar
06-07-2021, 09:44 AM #23
I thought the 2.4 came stock with 16 amp? Keep us updated if you find the cause. This is a good one.
06-07-2021, 10:04 AM #24
They do come stock with 16 amp. I don't usually mess with anything but 2.5 stuff. I didn't have any 9/16 amp stators, so I went with 40. im real close to changing it to 16 if I cant figure it out
Smalltownbassin liked this post
06-07-2021, 10:10 AM #25
06-07-2021, 10:11 AM #26
06-07-2021, 11:07 AM #27
that is a very clean, good lookin' motor.. well taken care of! hope ya get it figured out?
small town, they came out with tha 40 in '89 (optional) with tha junk water cooled stuff..
06-07-2021, 11:18 AM #28
It was bare 2.4 rotating assy I picked up for $300. It is just a project motor. Bobby V donated promax regulator plate for the cause.
06-07-2021, 11:22 AM #29
its still awful "clean".. you close ta Ft. Worth.. know bobby very well.. he's a good'un...........
06-07-2021, 11:22 AM #30
Have you looked at your control box? Like in case its a mechanical thing that shuts off the power? You step on the gas and the throttle plate in the box shorts out the keyed power or the hot supply to the key switch? That would explain the trim still working at the motor switch...it pulls power from somewhere else. Its far-fetched, but possible.
300R Gremlin
By RED ONE in forum Technical DiscussionReplies: 9Last Post: 03-19-2020, 01:24 AM -
Mercury Tech: Electrical Gremlin FYI
By vnemous in forum Technical DiscussionReplies: 0Last Post: 05-03-2017, 11:31 AM -
fat idle gremlin
By fortlaudypower in forum Technical DiscussionReplies: 1Last Post: 04-07-2016, 11:48 PM -
'95 200 XRi, electrical gremlin...I think...help needed
By silverbullet02 in forum Technical DiscussionReplies: 7Last Post: 06-23-2008, 12:18 AM
