Results 1 to 12 of 12
    Jun 2021
    Australia
    Black max vs Tower of Power
    Correct me if I'm wrong but there seems to be some overlap between the lower hp Black Max and the higher hp Tower of Power in the late 80s. There are more BMs for sale around my area than the older inline 6s. How to they compare in the 135hp model. Is one easier to work on than the othet? Do the V6s still tequire the casing to be split to change reeds and rings etc ?
    Pekin, IL
    V6 is easier to work on in my opinion. Only reason to split case on V6 is to access crank assembly. The inlines you have to split case to change reeds or access crank assembly. Pistons and crank assembly much easier to re-install on V6.
    Rock
    Team Junk
  3. Thanks Gilera thanked for this post
    Likes W2F a V-King, 25two.stroke liked this post
    Jun 2018
    Floating around
    The V6 in any iteration is a solid step up from the inline. If given the choice between the two the V6 gets my vote every time
  5. Thanks Gilera thanked for this post
    Likes FAST RALLY SPORT liked this post
    Dec 2018
    Maine
    I fully restored an inline a couple years ago and parts are expensive and a PITA to find. I got a v6 Mariner (same as blackmax) and you can feel a lot more power. Outboards are rated by horsepower but torque is more important and I feel like the v6 has more. Also if you go in the ocean the v6 has two switch boxes and 6 coils. The TOP has one of each. It might be the difference between limping home and paddling.
  7. Thanks Gilera thanked for this post
    Likes 25two.stroke liked this post
    Jun 2021
    Australia
    Quote Originally Posted by merc1250bayliner View Post
    Great point.
    Jun 2021
    Australia
    Quote Originally Posted by Forkin' Crazy View Post
    If it makes a difference, the last inlines, before they discontinued, had 6 coils and two switch boxes.
    I thought so. I was sure the 86 model 90hp I looked at had individual coils and two switch boxes.
    Dec 2001
    V6 is better........for what you want.
  11. Likes Forkin' Crazy liked this post
  12. #8
    Jan 2005
    Winnipeg
    one advantage might be if you can snag a grey band (86/87) TOP 115, those are closer to 150 PTO rated HP then 115 due to the way mercury played with models during that time. You may find that you can grab a good deal on one off those and get a good power motor for what you would spend on a V6 if that matters to you. They do have 2x switch boxes and also have integrated tilt/trim. There is almost a cult following of the TOP's, but that is probably rooted more in nostalgia then performance.
    79 Baja 16SS w/ 79 115 Merc
    1977 Whaler Montauk w/ 80 Yamaha
    1992 Mastercraft Barefoot 200
  13. Likes 25two.stroke liked this post
  14. #9
    Jan 2020
    Pinole, Ca
    Stay away from distributor I-6s
    Nothing wrong with the later CDI I-6s that have the same ignition system as the v-6s.
    I-6s are lighter but make less power.
    No reason to seek a I-6 over a V-6 really...get what you can find local.
    V-6s are MUCH easier to work on.
  15. #10
    Jun 2021
    Australia
    Thanks for everones opinions. Helps me a lot knowing what to look out for.
  16. #11
    Sep 2017
    Ashland city tn
    Get the black max v6. Only inline if u wanna restore original
    Jan 2005
    Winnipeg
    I have a soft spot of the I-6's...I think its the sound and the look. That being said, if its a non distributor I6 or V6 I think you will be happy either way. It really comes down to the condition of the motor. I wouldn't hesitate on either. Get whats available and in your budget.
  1. Power Trim Unit for 1978-1979 Mercury Tower of Power
    By 1975ss14 in forum Misc. Parts and Accessories
    Last Post: 10-05-2018, 01:40 PM
  2. Mercury 115 Tower of Power power trim
    By baja030 in forum Outboard Engines
    Last Post: 11-11-2017, 11:16 AM
  3. Mercury Tech: Help Tower O Power
    By ccouden in forum Technical Discussion
    Last Post: 06-17-2009, 09:52 AM
  4. tower of power in the 80's
    By mk55 in forum Outboard and Racing History
    Last Post: 08-18-2008, 06:20 AM
