Results 1 to 12 of 12
Thread: pro max overheating
06-05-2021, 07:54 PM #15000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
pro max overheating
I have a 1996 pro max 225 it was running fine then started running hotter still pumping good water switched lower units for one with newer water pump problem is worse replace thermostats next ???
06-05-2021, 11:59 PM #2
Dirt and gravel in your mid?
06-06-2021, 05:28 AM #35000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
no motor well cared for lots of fogging oil but it ran good for about 30 miles then started to overheat its a new motor to me but was well cared for by previous owner
06-06-2021, 06:36 AM #45000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
popit valve can this be removed?
06-06-2021, 12:09 PM #5
What is water pressure at idle, 4000rpm and WOT?
06-06-2021, 05:31 PM #65000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
water pressure low at idle just 3-4 lbs higher rpm around 10 up to 12 seems low but water really dumps out of tell tale
06-06-2021, 06:00 PM #7
You can check stats by pushing open and stick a piece of tag wire in open spot. Suspend in a pot of water, have thermometer in pot at same height as stats. Heat water and stats will drop off tag wire around 143°. If they don't fall untill much higher temp or fall at all. Replace them.
Forkin' Crazy liked this post
06-06-2021, 09:28 PM #8
Check to see if the poppit grommet hasn't been pushed out of the block.
Dave Strong, Forkin' Crazy liked this post
06-07-2021, 01:55 AM #9
also check tha large "washer" (seats against tha diaphram) for being warped?...
Dave Strong liked this post
06-07-2021, 06:32 PM #105000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Washer is definitely warped ordered new poppet kit, thermostats and water pump hopefully that will fix the problem. Thanks so much to everyone for the advice, S n F my favorite web site!
25two.stroke liked this post
06-07-2021, 06:55 PM #11
tlwjkw, Forkin' Crazy liked this post
06-08-2021, 06:05 PM #125000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Made a aluminum washer today thanks Dave
!!!!!!!!!!!!!!!!!!!!!!!overheating please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
By delucca54 in forum Technical DiscussionReplies: 1Last Post: 06-18-2012, 06:54 AM -
!!!!!!!!!!!!!!!!!!!!!!!!overheating please help!!!!!!!!!!!!!!!!!!!
By delucca54 in forum Technical DiscussionReplies: 10Last Post: 06-17-2012, 06:55 PM -
Mercury Tech: 250 EFI Overheating
By vdm in forum Technical DiscussionReplies: 11Last Post: 08-27-2008, 08:18 AM -
Overheating...Help!!!!!
By samann in forum Technical DiscussionReplies: 1Last Post: 07-28-2004, 10:29 PM
