Results 1 to 7 of 7
06-03-2021, 11:40 AM #1New Member
- Jan 2021
- nyc
2001 mercury 200hp efi need help to diagnose issue
I took motor apart thinking it was a bad bearing but did find anything wrong. What else could cause this. Compression was 120 on all 6cylinders. Have a link to YouTube video of engine running and noise. Any help is greatly appreciated.
https://youtube.com/shorts/VXJMke8mS0s?feature=share
06-10-2021, 12:56 PM #2
was your flywheel nut easy to remove?
06-10-2021, 02:53 PM #3New Member
- Jan 2021
- nyc
06-10-2021, 08:37 PM #4
I would check the timing on each cylinder and check for double firing..... How do the plugs look? Tops of pistons? Any look like they are suffering pre-ignition? How's the gear oil look? How does the splines on the drive shaft and crank look?
tlwjkw liked this post
06-10-2021, 08:42 PM #5New Member
- Jan 2021
- nyc
Plugs look good . Top of pistons also . I haven't checked but did replace the gear oil and it looked good.the splines on the drives haft looked good. Didn't check for double firing will check for that when I get it back running. BTW thanks for the reply I appreciate it.
06-14-2021, 12:46 PM #6Member
- May 2015
- Southwest Georgia
- 96
- 7
- 10
- 19
Have you checked for a loose tuner or broken or bad reeds?
06-14-2021, 10:42 PM #7"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
Mercury 200hp race - starting issue
By KnotNow in forum Technical DiscussionReplies: 9Last Post: 06-15-2019, 05:07 PM -
300xs spark plugs diagnose coil issue
By John2250 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 16Last Post: 09-10-2018, 09:37 PM -
Help diagnose livorsi GPS speedo issue
By gregpro50 in forum Technical DiscussionReplies: 7Last Post: 07-28-2012, 06:06 PM -
Help diagnose volvo penta trim pump issue
By gregpro50 in forum Technical DiscussionReplies: 3Last Post: 07-26-2011, 10:57 PM -
TPS 2001 Mercury 200hp
By rickriddle in forum Technical DiscussionReplies: 4Last Post: 05-15-2011, 10:05 AM
