Results 1 to 15 of 36
06-02-2021, 04:38 PM #1Junior Member
- Jun 2021
- Inks Lake, TX
- 13
mercury 200 xr6 bogs down at 2000 to 2500 rpm under load
New to forum and by no means a mechanic, but can turn a wrench. With that said I have a 2001 Mercury 200 XR6, carbed not efi. Can not figure this thing out. When I first take of in the morning after idling out of no wake zone she gets up on plane and ruins great. After stopping for a bit to fish then firing it back up it idles great and will work under load up to about 2000 rpm’s then it just sticks there. If I slow down and speed up a few times and jockey the throttle some it will sometimes seem to catch its stride and take of on plane and run great. Same problem after I stop again for a bit. What I know:
*air intake into gas tank is clear
*pick up tube in tank is clear and unrestricted
*new hoses, primer bulb, water separator, and filter
*new plugs
*compression shows all cylinders in spec, although leak down test shows #4 leaking slowly
The motor will rev up in neutral during these episodes but will bog down around that 2000 rpm mark under load and sometimes stall out if I throttle back. It will always start right back up and idle fine, it is not consistent, because occasionally it will plane out and go with no issues but it happens more often than not.
Sorry for the long post but I need some serious help.
Thanks
06-02-2021, 07:23 PM #25000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Sounds like it is loading up. Maybe a needle sticking open and causing it to flood while it sits.
06-02-2021, 11:12 PM #3Member
- Jan 2005
- Winnipeg
- 54
It may not be a help but check your triger and stator. I had a 50 merc that did that. I thought it was fuel related for the longest time. Turns out the heat was effecting the trigger. Eventually it just wouldn't run good anymore. It was noticible when you put a timing lite on it and its jumping all over with erratic sparks
79 Baja 16SS w/ 79 115 Merc
1977 Whaler Montauk w/ 80 Yamaha
1992 Mastercraft Barefoot 200
06-03-2021, 07:26 AM #4Junior Member
- Jun 2021
- Inks Lake, TX
- 13
I’m thinking your on to something Spidermonkey, I have cleaned the carbs and still have the problem. Electrical is my weakness but I will do some research. Don’t own a timing light but know where to get one. How hard is it to replace stator and trigger? Will I have to reset timing?
Sorry for my ignorance.
06-04-2021, 09:20 AM #5Junior Member
- Jun 2021
- Inks Lake, TX
- 13
After very close inspection, I can see that some of the wires on the trigger look like they have been overheated and have frayed in some places. Not sure this is the cause of my current problem but a problem none the less. I have ordered a new stator and trigger and will install and test next week. My internet research does not indicate that I will need to adjust timing for this repair.
06-04-2021, 09:30 AM #6
you should do a sync n link and check timing after replacing trigger.
Jimmopotomus thanked for this postSmalltownbassin liked this post
06-04-2021, 10:04 AM #7Junior Member
- Jun 2021
- Inks Lake, TX
- 13
Got it, thanks
06-06-2021, 08:13 AM #8
Welcome to scream, Jimmo. Also make sure you have the special flywheel puller tool. Hint: it ain't coming off without it. Dirt simple and works. Get the one with lifting eye, too. Might need it down the road. Good luck
Jimmopotomus thanked for this postJimmopotomus liked this post
06-06-2021, 09:13 AM #9Junior Member
- Jun 2021
- Inks Lake, TX
- 13
Thanks RGSAUGER, I do have the puller and the new trigger and stator come in today. I will probably tackle it tomorrow, today I’m putting a four bank charger in my sons procraft then hitting the lake for a bit if the weather holds.
rgsauger liked this post
06-06-2021, 11:34 AM #10
And welcome to Scream. You'll find a bunch of folks who know a LOT about motors and setups here. Real good and helpful community.
06-07-2021, 02:15 AM #11
if you want send me an email addy and i'll send ya an OEM manual in pdf that will have your motor in it.. won't be listed as a 200 XR6 but will be same as normal 200 carbureted motor.... tha "200 XR6" is a nitro badging thing...
Jimmopotomus thanked for this postForkin' Crazy liked this post
06-07-2021, 07:00 AM #12Junior Member
- Jun 2021
- Inks Lake, TX
- 13
wvjscott@gmail.com
much appreciated
06-07-2021, 07:32 AM #13
sent.. let me know when ya get it....
06-07-2021, 09:18 AM #14Junior Member
- Jun 2021
- Inks Lake, TX
- 13
Got it, This thing is a gold mine.
really appreciate the guys on this forum.
06-08-2021, 06:23 AM #15
rock liked this post
1996 merc 150 stalls under load at 2000 rpm
By glaston in forum Technical DiscussionReplies: 3Last Post: 07-24-2011, 10:28 PM -
2.4 Bogs until around 2500 rpm
By bm1961 in forum Technical DiscussionReplies: 3Last Post: 05-28-2007, 07:30 AM -
300 Evinrude Bogs Under Load
By Li'l Toy in forum Technical DiscussionReplies: 10Last Post: 11-28-2005, 11:20 AM
