Results 1 to 10 of 10
Thread: 200 trim ram needed
06-02-2021, 04:14 PM #15000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
200 trim ram needed
I had some very bad luck, I had some engine problems out in the middle of the lake. Dropped a socket down the jack plate. Didn't think much of it other than another donation to the lake. But then the trim started leaking. Pulled the trim apart to replace the o-rings. put then found the lost socket. I was between the ram and the transom plate. as you know, there isn't room there for a socket. with the trim down, it cracked the body of the center trim ram. So I need the center trim ram for a 90's 200 EFI 20 inch. Maybe a trim unit with a bad motor? and this is all on a 200 that has just been rebuilt, and I just started breaking it in.
06-02-2021, 10:29 PM #2
Assuming it is a 3 ram system and not a single ram?
I have a boat or two.... that I never get to drive
06-03-2021, 08:27 PM #35000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
06-03-2021, 09:00 PM #4
I will see what I have available.....as well as some of my friends
06-03-2021, 09:31 PM #55000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
Thanks, I'm hitting up all of the shops I know to see anyone has something sitting around. For right now, I swiped the trim off my Pro Max. Not what I really wanted to do, But they are talking 90 this weekend.
06-04-2021, 11:45 AM #65000 RPM
- Mar 2015
- Oregon
- 145
- 7
i have several pm me a phone number
06-04-2021, 10:31 PM #75000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
pm sent, also I only need the ram. I'd rather not buy a whole trim unit if I don't need to. Also, my trim sensor fell apart when I took it off. Does any know the part number?
06-05-2021, 12:28 AM #8I have a boat or two.... that I never get to drive
06-05-2021, 10:38 AM #9Junior Member
- Sep 2015
- wilmington,Il
- 22
PM sent
Troy
06-07-2021, 04:53 PM #105000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
I'm very thankful, Got what I needed. Now to get everything back together. Thanks guys
OMC Tech: '77 85HP Trim help needed
By turbotadd in forum Technical DiscussionReplies: 4Last Post: 05-15-2009, 09:39 PM
