Results 1 to 10 of 10
    Aug 2014
    West Bend, WI
    200 trim ram needed
    I had some very bad luck, I had some engine problems out in the middle of the lake. Dropped a socket down the jack plate. Didn't think much of it other than another donation to the lake. But then the trim started leaking. Pulled the trim apart to replace the o-rings. put then found the lost socket. I was between the ram and the transom plate. as you know, there isn't room there for a socket. with the trim down, it cracked the body of the center trim ram. So I need the center trim ram for a 90's 200 EFI 20 inch. Maybe a trim unit with a bad motor? and this is all on a 200 that has just been rebuilt, and I just started breaking it in.
    WI
    Assuming it is a 3 ram system and not a single ram?
    I have a boat or two.... that I never get to drive
    Aug 2014
    West Bend, WI
    yep, the center is a ram, I call it three ram, but only the center is a ram.
ID:	488163Click image for larger version.
    WI
    I will see what I have available.....as well as some of my friends
    Aug 2014
    West Bend, WI
    Thanks, I'm hitting up all of the shops I know to see anyone has something sitting around. For right now, I swiped the trim off my Pro Max. Not what I really wanted to do, But they are talking 90 this weekend.
    Mar 2015
    Oregon
    i have several pm me a phone number
    Aug 2014
    West Bend, WI
    pm sent, also I only need the ram. I'd rather not buy a whole trim unit if I don't need to. Also, my trim sensor fell apart when I took it off. Does any know the part number?
    WI
    Quote Originally Posted by Poky View Post
    I found a single ram, that won't help you.....also have a buddy that has what you need but in a complete trim/clamp/swivel/& can so I would look into Treeguy's stock before we go down the road you don't want, nor need to take haha
    Schramer
    Sep 2015
    wilmington,Il
    PM sent
    Troy
    Aug 2014
    West Bend, WI
    I'm very thankful, Got what I needed. Now to get everything back together. Thanks guys
  1. OMC Tech: '77 85HP Trim help needed
    By turbotadd in forum Technical Discussion
    Last Post: 05-15-2009, 09:39 PM
