Results 1 to 3 of 3
Thread: 300x powerhead re torque?
06-02-2021, 11:19 AM #1Member
- Oct 2018
- long island new york
- 60
- 18
- 14
Should powerhead be re torqued after heat cycle on a 300x using OEM performance gaskets??
06-06-2021, 05:53 PM #2
1200 ,
As long as you have an accurate wrench and a a crow's foot to reach a couple few that are hard to get at .. then yes it's a good idea.
I don't know if you have the factory bulletin about their weak azz blocks ..
#9 and #10 when torqued to 40 ft / lbs pulled number six cylinder out of round and they had to replace quite a few powerheads.
But they recommend , 1 - 8 go to 40 ft /lbs
And you leave 9 - 10 back at 25 ft / lbs
Port side , directly under number six cylinder ...
Capt.Insane-o liked this post
06-06-2021, 08:19 PM #3Member
- Oct 2018
- 60
- 18
- 14
thanks yes 9 10 left at 25
Mercury 2005 300X Complete Drop On Powerhead (Low Hour Virgin Powerhead)
By mragu in forum Outboard EnginesReplies: 6Last Post: 05-18-2016, 09:45 PM -
300x powerhead x2
By topgun marine in forum Outboard EnginesReplies: 4Last Post: 08-23-2014, 03:07 PM -
Bent prop shaft on 300x...Torque master
By blackbird345 in forum Technical DiscussionReplies: 4Last Post: 11-15-2012, 08:35 PM -
300x Powerhead
By concord18 in forum General Boating DiscussionReplies: 7Last Post: 08-10-2008, 08:32 PM -
powerhead torque
By lild in forum Technical DiscussionReplies: 1Last Post: 05-20-2008, 05:12 PM
