Results 31 to 41 of 41
Thread: 2003 Mercury 2.5 xr6 porting
06-06-2021, 03:14 PM #31
Bullet ,
I got involved for a reason , stayed for another , and now as the voice of reason you gave me food for thought as to why I should step away from the ledge .
Thanks brother .. I'm done with this thread ...
06-06-2021, 03:51 PM #325000 RPM
- Sep 2011
- Deplorableville
- 740
- 1281
- 76
- 3144
- 1452
Thanks again for sharing your infinite wisdom with us on here. I for one enjoy seeing the pictures of your machine work. I just started tig aluminum a few months ago, yours look pretty dang good. I might have to hit you up for some tips.
rgsauger liked this post
06-09-2021, 10:52 AM #33Member
- May 2021
- Florida
- 55
Guys, mine is carbureted and ORinged. Mine has the larger carb offering for the xr6 for that year. Four petal reeds.
06-15-2021, 08:04 PM #345000 RPM
- Sep 2011
- Deplorableville
- 740
- 1281
- 76
- 3144
- 1452
I don't know how to help you bud. Whenever some posts for help, someone that knows how to help tries to help. Someone else chimes in with useless info, then an arguement starts. The people who can and will help get chastized, then get out of the thread. Maybe just PM Chaz with the question and ask him directly to keep it simple.
06-16-2021, 04:30 AM #35
Smalltownbassin liked this post
06-16-2021, 06:42 AM #36
So i was rattling my marbles around about this a couple months ago. My goal was to take the CDM lectrics off a donor XR6 to use on a new ported FF build. That dang ECM box has been my only hang up. Not only is it a retard module but its necessary to convert stator voltage into usable pixies for the CDM packs. So there's some other magic going on in there that the older retard boxes don't do. Once i had the opportunity to bounce this around with a blond headed, danish eatin foreigner who has more brain cells than i do, it appears that the ECM from a CDM EFI motor has the potential to solve the retarded timing dilemma. Since the ECU is what's responsible for holding back your rippums at WOT on an EFI, the ECM box does not have that circuit which banes the carbbie cousin. I did a lot of research on this and have only seen one mention of it in an archived thread. If this actually works and/or someone has tried it, PLEASE let us all know.
OnPad liked this post
06-16-2021, 06:58 AM #37
To the OP, i went through the same questions youre bringing up a few years ago. It didnt take long to add up the cost of making a 200 out of a 150 and came up about the same as just buying a 200. Look at it like this, if you convert your 150 into something else you have one motor. If you spend that money on a 200 you have 2!
bullet123 liked this post
06-16-2021, 07:55 AM #38
What tommy (tlwjkw) was trying to get across earlier in this post is that CDM/Oring motors are much harder and expensive to get bolt on horsepower.
06-16-2021, 08:30 PM #39Member
- May 2021
- Florida
- 55
06-19-2021, 05:02 AM #40
like i was sayin' at tha start.. its not tha motor itself, its tha electronics that limit its performance.. doesn't make any difference with efi and/or carb... it has an control module (part number 857185T1 in your case) that limits its performance period.... all production 2000 up 2.0/2.5's do.. as far as i know there is no one or no product that can change it.. plus its got that heavy assed 40 amp flywheel.. sure ya can make it turn up to its limits a little quicker but 6 grand, give or take a coupla hundred, is gonna be all there is.................................. hope ya get it figured out.. its your choice..
06-19-2021, 05:19 AM #41
here is a description of some of what that module actually does
The control module provides rev-limit (carb models), bias control, shift stabilizer, idle stabilizer, injector timing signal (EFI models), and low oil warning.On carburetor models, the rev-limiter affects the cylinders in the following sequence2-3-4-5-6-1. As the engine rpm exceeds the maximum specification (5900 ± 100), thecontrol module will retard the timing on cylinder #2. The controller will retard the timinga maximum of 30 degrees and then, if necessary, stop spark on the cylinder. If the enginerpm is still above the maximum specification, the controller will begin to retard timing onthe next cylinder, then stop spark, continuing in sequence until the engine rpm drops below the maximum specification.
save ya $$$$ and find yourself a good 225PM for performance and reliability........... jmo.Last edited by tlwjkw; 06-19-2021 at 05:24 AM.
David Borg liked this post
Mercury 2.0 exhaust chest porting
By 2.4Viper in forum Technical DiscussionReplies: 28Last Post: 02-07-2021, 04:22 PM -
2003 mercury 250 efi ECU
By ikelyn in forum Parts WantedReplies: 0Last Post: 12-25-2019, 03:03 PM -
2003 Mercury 2.5L Mercury Repower block / powerhead with 50± hours $1,800.
By Iceout in forum Outboard EnginesReplies: 6Last Post: 03-30-2015, 06:32 PM -
Question on Z porting VS. Bridge porting?
By Riverracer280SS in forum General Boating DiscussionReplies: 5Last Post: 09-05-2001, 08:52 AM
