Results 1 to 5 of 5
    Feb 2021
    Milwaukeeish
    How do you make longer foam stringers when they only sell 4x8 sheets?
    I've been looking into coosa and divinycell and whatnot, but they're all 4x8 sheets. I need a stringer that is 12' long.
    What do?
    Feb 2021
    Milwaukeeish
    Thank you, okay I will look into this as the weight savigns seems substantial
    Calgary, Alberta
    Maybe I'm losing it but I had thought there was a reply here recommending a scarf joint. In any event, that is the correct answer and is standard practice in wooden boat building to "stretch" lumber. Bond the joint with epoxy and wrap it with glass and it will be at least as strong as the rest of the stringer.
    FYI in many boats there will be transverse bulkheads closer than 8' spacing so this becomes a non-issue.
    Matt
  4. Likes David - WI, ADDvanced liked this post
    Your not losing it Matt. I started out intending to help him. he went sideways so I changed my mind and deleted the post. I won't help someone that hurls insults and then asks for help with the next breath.
  6. Likes TwzteD, SS Minnow, rgsauger liked this post
    Calgary, Alberta
    Fair enough, I don't blame you one bit. I missed that apparently.
    Matt
  1. progression 24 foam stringers
    By bobhoffmann in forum General Boating Discussion
    Last Post: 09-25-2018, 01:44 PM
  2. Wraping hi density foam into tight places without using heat and makingthe foam hard
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 01-22-2017, 05:54 PM
  3. Where to find, Fiberglass wrapped foam stringers
    By Carter Powell in forum Fiberglass and Composites Discussion
    Last Post: 10-23-2008, 09:18 AM
  4. Fiberglass wrapped foam for stringers ?
    By Carter Powell in forum Technical Discussion
    Last Post: 10-14-2008, 11:38 AM
  5. Im going to make a foam transom, hey techno!
    By aircraftman in forum Technical Discussion
    Last Post: 08-15-2002, 04:36 PM
