Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
    Jun 2014
    Goldsboro, NC
    electric oil injection pump conversion kit
    Anybody remember an electric oil pump conversion kit for 2.4 and 2.5 L that replaced the crank driven Mikuni pump? Allegedly developed by a Merc engineer? Saw one years ago, but not since...
    Ft. Lauderdale, Fl
  3. Likes David - WI liked this post
    Jun 2014
    Goldsboro, NC
    Well, unfortunately I have a 1988 200, but thank you for the reply. Might you have any other suggestions?
    Jan 2003
    aalsmeer
    Premix!
  6. Likes Forkin' Crazy, rgsauger liked this post
    TX......somewhere?
    Quote Originally Posted by Barracudamooda View Post
    think is was called "auto lube" maybe?.. haven't seen are heard of it in years..............
  8. Likes David - WI, 25two.stroke liked this post
    Ft. Lauderdale, Fl
    I think that was Evinrude/Johnson. Was a piece of junk.
  10. Likes tlwjkw liked this post
  11. #7
    Jun 2014
    Goldsboro, NC
    Quote Originally Posted by Forkin' Crazy View Post
    Yep!!! If you happen to be a bit oil rich, it won't hurt a thing!
    Well duh! With all due respect, if I wanted to do that, I would not have asked the question. Anyone else have a helpful response? Thanks in advance...
  12. Thanks Forkin' Crazy thanked for this post
  13. #8
    Plainville, CT
    Pretty sure the one in the link above is the only one ever made or sold, and yes I believe it was build by an ex Merc Engineer.
  14. #9
    Mercury has an electric oil pump similar to the OptiMax oil pump without all the extra output lines... but I don't know how you would power it without a custom controller. I'll take a picture tomorrow if I can.
  15. #10
    Feb 2013
    Northern Cal
    It doesn't replace the Mechanical Mikuni oil pump but instead drives it with a 12 VDC motor via a micro controller programmed to mimic the crankshaft gear rotation speed . A spark coil signal is inputted to the controller to monitor RPMs to adjust pump speed . The linkage on the throttle cam is still required to adjust the pump oil output though .
    The one flaw is that they didn't utilize a different pump that did not require the linkage to the throttle cam . They could have varied the oil pump output with program code instead of a linkage and it would have been a lot cleaner , simpler system .
  16. #11
    Jun 2014
    Goldsboro, NC
    Are you aware of a current source for the conversion system?
    Feb 2013
    Northern Cal
    Yea the Optimax oil pump is just a solenoid driven plunger controlled with a PWM signal from the ECM .
    Do you know which Merc engine they made the pump with a single output for or have a part # ?
  18. #13
    Feb 2013
    Northern Cal
    It was only available for a short time it seems . I purchased a used one about five years ago that came with no paperwork . I was able to contact the guy that designed and sold it "Robert Kachelek " and he emailed me the installation paperwork after I provided him with the serial #
  19. #14
    This one is off an '07 2.5L 150hp EFI motor... one inlet, one outlet versus like 7 outlets on the Opti pump.
ID:	487783 Click image for larger version.
  20. #15
    Ft. Lauderdale, Fl
    Quote Originally Posted by H2Okie View Post
    write upon it?
    Kit can prevent oil gear failure - Soundings Online
  21. Likes David - WI liked this post
  1. Mercury Tech: Looking for Performance Fuel Injection for 7 pedal 2.5 Steel bore conversion
    By 86vintage in forum Technical Discussion
    Last Post: 08-07-2016, 09:14 PM
  2. Mercury Tech: what do people think about the marine solutions inc. electric oil injection?
    By pcrussell50 in forum Technical Discussion
    Last Post: 06-09-2013, 12:33 AM
  3. Replies: 6
    Last Post: 05-12-2005, 02:21 PM
  4. electric fuel pump, through factory pump, or by pass?
    By WATERWINGS in forum Technical Discussion
    Last Post: 06-02-2003, 11:38 AM
  5. Electric Fuel pump-vs- stock pump
    By B.Mac in forum Technical Discussion
    Last Post: 10-11-2001, 03:49 PM
