Results 1 to 4 of 4
Thread: Prop pitch help
05-18-2021, 11:54 AM #1Junior Member
- Nov 2020
- Nj
- 15
Prop pitch help
On my checkmate predictor I'm currently running a Michigan wheel 13/21 trimmed up and at 3" below the pad I will see 5800 rpm the motor is a 115 1984 tower of power merc I wanna try another prop to help keep the bow up I'm thinking a PowerTech ptr in either a 13.5/21 or 22p. I'm not sure where the motor makes max power and if a 22p would produce more speed. Any suggestions would be appreciated
05-18-2021, 01:43 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
With the TOP I would keep the rpm up high. A big prop and lower rpms will make it slow out of the hole and stress the engine more. The power tech is a bow lifter. Found this...http://www.bbcboards.net/showthread.php?t=716710
Check82 liked this post
05-21-2021, 03:43 AM #35000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
I had good performance with a through the hub 23 chopper paired with a 150 TOP on a 16ft Sidewinder lo pro. Pulled out of the hole and top end.
05-22-2021, 09:59 PM #4
Yep, what these guys said.....definitely don't want to over prop the tower and chopper is key to bow lift.
Post a video running, all of us merc fans can't resist the sound of an inline winding out!1977 Hydrostream Vector 2.5 Promax
What Pitch Prop Should I Go With?
By FUJIMO in forum General Boating DiscussionReplies: 10Last Post: 10-24-2015, 04:28 PM -
prop pitch
By jem in forum Technical DiscussionReplies: 1Last Post: 10-08-2007, 09:13 AM
