Results 1 to 8 of 8
Thread: Fuel Pressure Regulator
05-12-2021, 09:21 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
I have a fairly modified 225 promax powerhead (260 porting/145 compression) just setting it up. I am starting with a R32 ECU and a 39psi regulator but was thinking of bumping up to a 56psi regulator,has anyone tried this combination with success. Thank you
05-12-2021, 10:18 PM #2Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,741
- 377
- 2934
- 5184
Try a adjustable regulator that way you can dial it in however you like.
05-13-2021, 10:32 AM #3
That ECU is mapped for 39psi regulator so going to 56psi will just make it run rich. If you want to go 56psi you should get an ECU with a 56psi curve.
05-13-2021, 11:21 AM #4
Yeah, you won't get performance gains, it will actually make your motor run horrible. You have to swap ECUs & regs together (or re-chip). If you have a feeling your ECU is a bit off because you did mods to the block then you can go to an adjustable and make little tweaks to the whole RPM range. You can add a couple psi and make it a little richer all around to compensate for the porting/increased flow.
I run one and love it!
Trevor Sawyer liked this post
05-14-2021, 07:00 AM #55000 RPM
- Jun 2014
- United States
- 147
- 29
- 40
On my modified 2.5 225, that R32 ecu burned a piston, and according to my pyrometers was too lean to stay in a safe temperature range. I’d go with an ACU from Brucato and a steam wheel. Even with an adjustable regulator I couldn’t get the temps down by increasing fuel pressure. This is just my personal experience.
25two.stroke, pkstv liked this post
05-14-2021, 01:05 PM #6
The stock R32 promax ecu will be too lean and not supply enough fuel for the porting done to the motor. I would look into a Powers for a Ecu.
1998 SS 2000 94 260ss
Speed cost how fast you want to go
Allison and Merc is there anything else?
05-14-2021, 08:28 PM #7
I own a 225 promax with a 56 psi fuel regulator and a brucato ACU that’s got a 260 fuel curve mapped for 56 psi . You need to use the correct regulator psi that your ACU is programmed for .
05-15-2021, 06:32 AM #8Bud Conner "Heathen" "Defending Our Constitution"
Dave Strong, pkstv liked this post
Fuel pressure regulator
By dbug10 in forum Technical DiscussionReplies: 6Last Post: 03-02-2015, 11:29 AM -
Do I need to run a fuel pressure regulator with a Holley Red fuel pump?
By Steve2ManyBoats in forum Technical DiscussionReplies: 14Last Post: 03-31-2011, 08:09 AM -
Recommended inline fuel filter and fuel pressure regulator
By topkick in forum Technical DiscussionReplies: 2Last Post: 09-20-2005, 09:25 AM
