Results 1 to 15 of 75
05-12-2021, 07:22 AM #1
Checkmate Pulsare 2400 with 300R performance
I recently refitted a 2007 Pulsare 24 with a Mercury 300R. It's the crawl through bow rider and I have a bow cover to stop the wind tunnel the design creates. She's barely broken in with about 8 hours. I did it by the book, <1 minute WOT before 5 hours etc.
Yesterday morning I found Lake George FL with almost no wind and a fairly calm flat surface. The prop is a ProMax 23p right out of the box.
I was able to get 72.5 mph on 3 separate attempts each time at 6400-6500 rpm but never clipped the limiter. I don't think there's much left.
I've read where the Bravo1 FS is more likely to create chine walk and I have to say there was very little with this prop and it was mostly manageable.
I am by no means an expert with this boat. I am still figuring out jack plate height and trim but I feel like I'm close to the sweet spot.
I'm curious to hear some recent performance numbers from the same hull and motor with other propellers.
Also Wildman Randy has agreed to wring it out to see if there's more sometime soon so we'll see.\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
05-12-2021, 07:30 AM #25000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
i'd check your tack because you are probably clipping it just barely... I'd bump up to a 24 promax and see what that does as it sounds like you might be a hair on the small side pitch wise
05-12-2021, 06:12 PM #3
I've got to believe there's a lot more to be had. I used to run Checkmates, so I know a little bit about them. My other reference point is my 22 Progression with only a 250R on it. I'm 2 feet shorter and certainly lighter, but I'm also down 50 HP on you. But I'm turning a 30 pitch BBlades Blaster 4 blade and I'm almost on the limiter - at 88 MPH. And that's with very little playing with setup. I think Randy will find you something.
1992 Progression 22
Mercury Racing 250R
05-12-2021, 06:30 PM #4
2 feet shorter, 800 pounds lighter, 7 inches narrower, 50 hp less. Apples and oranges.
But I hope you're right. The only other 2400 I see with any recent data is saying 72 mph. There's a 24 with a 400 claiming 80.\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
05-12-2021, 06:31 PM #5
Then there is this thread:
2014 Checkmate Pulsare 2400 top speed help... (screamandfly.com)\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
05-12-2021, 07:38 PM #6
What gear ratio is your 300? are you running a torque master or sport master?
05-13-2021, 06:21 AM #7
Tm 1.75
05-13-2021, 06:25 AM #8Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
That is a "fat" case to be dragging through the water. Wildman will know for sure but you may not get much more.
05-13-2021, 06:25 AM #95000 RPM
- Dec 2002
- Biloxi,MS
- 176
- 9
- 36
I have a long deck Pulsare 2400 with a 300XS. The best I've run has been 78.2.
-Past:
1978 Glastron GT-150
1991 Allison XR2002
1996 Triad V-21 ski
2000 Allison SS 2000
1996Allison GrandSport w/280 Merc
2005 Hydrostrem Venom Comp w/280 Merc
1989 Boston Whaler Mischief W 70 Yamaha
2009 Checkmate Pulsare 2400 w/300xs
1982 Allison Gt 20(total restore) w/200 XRI
http://forum.allisonowners.com/showthread.php?t=11151
2000 Allison GrandSport w/ 280SS
-Present:
2022 Allison XB21 Prosport SUB w/ 280 SS
05-13-2021, 06:48 AM #10
I set up a 350 Verado on a 23 Kryptonite with a stock 5.44 TM and it was nearly surfaced and all stock water holes were wide open and had tons of water pressure...... boat ran 88mph without blowing out. (A mercury Engineer said they never ran one above 86 without blowing out)
05-13-2021, 06:48 AM #11
Interesting thread. I have a Key West 210BR (pad bottom bay reef) running a 250 ProXS 4S with a 23P Bravo 1FS and it’s seen 71 @ 6200 (limiter) light and it’s a handful at that speed. I’d love to get together and swap props since my experience with the ProMax on the Talon tells me it may settle my KW down.
There’s also some speed available if you plug some of the holes on the side intakes. The original TM2 lower came with 3 holes per side, they changed that to 5 since a number of the bass boat guys were dragging the lower though weeds and clogging the low pickup and overheating the motor. I plugged the top 2 holes and run it 1” higher than I could before and that got me over the hump from 65 mph to 70. You just have to be careful, running it high for speed will starve the motor in turns real fast. I have an adjustable plate so I run it low most of the time but have a mark on the gauge for balls outMark
05-13-2021, 08:12 AM #125000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
The long deck is a decent amount lighter than the mid or BRX model.... I wonder how much set back and how high he is running.
05-13-2021, 08:31 AM #135000 RPM
- Dec 2002
- Biloxi,MS
- 176
- 9
- 36
Running 18" of set back currently. Was running 20" for awhile. Lower unit is about 2.5" -2 1/4 " below pad. I have run 28 Bravo 1, 27 Tempest Plus and 25 Trophy Plus.
-Past:
1991 Allison XR2002
1996 Triad V-21 ski
-Present:
05-13-2021, 09:13 AM #145000 RPM
- Feb 2010
- wisconsin
- 475
- 32
- 21
- 117
- 168
Have you tried going up at all?? With that much setback it seems like that could go up in height.
05-13-2021, 11:37 AM #155000 RPM
- Dec 2002
- Biloxi,MS
- 176
- 9
- 36
I have a hydraulic jack plate on boat. So, yes I have tried to run at higher heights.. These boats are heavy and running any higher the boat wants to squat. I wouldn't call the Checkmate 2400 a surface piercing prop type of boat. That's why you run the torque master lower unit not a sportmaster on them. I also have an Allison and the set up is totally different between the two.
-Past:
1991 Allison XR2002
1996 Triad V-21 ski
-Present:
Checkmate pulsare 2400/mercury verado 300 pro
By JUPITER PULSARE in forum Hulls larger than 20'Replies: 28Last Post: 10-22-2021, 01:02 PM -
Checkmate Pulsare 2400 BR and Pulsare 2400 BRX from last Sunday.
By JUPITER PULSARE in forum General Boating DiscussionReplies: 19Last Post: 10-02-2016, 08:48 AM -
2012 Checkmate Pulsare 2400 Brx
By faztbullet in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 06-24-2016, 06:54 AM -
By RDAglock in forum General Boating DiscussionReplies: 12Last Post: 07-14-2014, 06:55 PM -
Checkmate Pulsare 2400 or Superboat 24ft
By swingray in forum General Boating DiscussionReplies: 9Last Post: 05-28-2008, 01:57 PM
