Results 1 to 4 of 4
Thread: Cage bearing or stacked
05-12-2021, 01:51 AM #15000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
Building a monster Big Johnson 3.3 long rod ,back liner ported ,DBR spect sleeves an pistons I have built plenty of rebuilds question is 3 ltr have loose needles and 3.3 have caged rod bearings piston side / personally I think more needles better load distribution on wristpin an rod end 3.3 were loafing as a injected engine this one will be close to 380 + hp any thoughts on this ??
05-12-2021, 06:31 PM #2
I like the caged with a single needle in each slot. all needles can skew and have more friction at high rpm/load
TEXAS20225, racer liked this post
05-13-2021, 05:04 AM #3Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
yes it all about the rolling friction at high revs, hence caged in race motors.
OMC went crowded to get them to run at 100:1 for fishing..Last edited by powerabout; 05-30-2021 at 05:15 AM.
05-16-2021, 09:05 AM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
The non caged also tend to break the thrust washer
powerabout liked this post
Bearing carrier for a cle left hand (stacked bearings)
By SUNKIST in forum Parts WantedReplies: 4Last Post: 11-08-2016, 03:56 PM -
Plastic cage rod bearings vs metal cage mercury 2.5
By Davidpkl in forum Technical DiscussionReplies: 9Last Post: 07-16-2015, 09:20 AM -
OMC Tech: rod bearing cage question
By duke_snyder in forum Technical DiscussionReplies: 6Last Post: 08-16-2014, 09:52 PM -
Stacked burnout
By 1BadAction in forum The Scream And Fly LoungeReplies: 20Last Post: 07-20-2008, 01:38 PM -
top end cap bearing plastic cage,can it be change to metal cage
By camaro7081 in forum Technical DiscussionReplies: 0Last Post: 12-24-2006, 05:02 PM
