Results 1 to 14 of 14
Thread: A13 ecu
    Jan 2020
    Pinole, Ca
    A13 ecu
    I got 2 tested and run, they are good. I have TPS to go with them for a tad extra if you need them. 1 rotary and 1 vacuum module. $350 each + shipping and willing to make a combo offer with other stuff you may need.
    Apr 2021
    sacramento
    will it work on mine before i spend 1500 at brocato? also need lite flywheel,solid motor mounts, gaskets for the exhaust plate,2.4 exh tuner. harness is 16pin,vacuum
    Jan 2020
    Pinole, Ca
    Call me 510-418-4911 - Jacob
    I have a few of the things you are asking for, not sure about all of them. If you are in Sac I can drive up there and help you sort out any problems you may have. Not sure what engine you have and please forgive me if I've answered your posts in the past and should know you...but I comment on so much stuff I forget half of it. If someone posts about and engine I know about I try my best to help...
  4. Thanks rprinzo thanked for this post
    Jan 2020
    Pinole, Ca
    If you are asking if this will work on an FF 200 efi...it will not. I do have 1 or 2 200 efi boxes if you need one. I would test them to make sure they are good before I sent you one.
  6. Thanks rprinzo thanked for this post
    Jun 2020
    southeast GA
    will one of them tps sensor work on my 93 260 and if so how much
    Jan 2020
    Pinole, Ca
    Yes, one of them (17814A11) will work on a 260 with the analogue ECU.
    Apr 2021
    sacramento
    ive got a stock one
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by rprinzo View Post
    ive got a stock one
    What are you looking for then? This will not work on a lazer injection motor. Brucato will, this will not. I have a light flywheel and crescentbar may have a good used set of solid mounts for you...I am about to drive up to his house so if you want anything he has I can bring it back down for you. I will help if I can, but I am having trouble understanding what you want/ what you are trying to build.
    Apr 2021
    sacramento
    ill call you,just been doin a ton of research, and am starting to put the puzzle together. final product id like to have is a motor thatll push my 20' skeeter to mid 70s. ive gotten 71 out of it but not in the last two years,its had an intermittent rpm drop the last year and have yet to figure that out. it arrived at the rebuilder this morning so i plan to have it back in 2-3 weeks.ive played the hi hp game on the auto side for 40 years but this is my first marine build. i wrenched for my son for 10 years in 2stroke karts. im not a dummy,just learning a new game
  12. Likes 25two.stroke liked this post
    Jan 2020
    Pinole, Ca
    Alright. Thats making a bit of sense. If you are thinking of keeping fuel injection and going the modification route then you should save the hassle later and go with a Brucato and EGT probes now. Just an idea. Talking through it on the phone is easier.
  14. #11
    Jan 2020
    Pinole, Ca
ID:	486905Click image for larger version.
    A couple of the TPSs I have. I would rather sell them with the ECUs rather than separately.
    Apr 2017
    pa
    5 Post(s)
    How much for a stock 200 ecu?
  16. #13
    Jan 2020
    Pinole, Ca
    I got 2 200 ECUs, one I know is good and the other I have no idea. I can run a test on it before I sell it. $300 for the one off a good running motor and $200 for the other. I also have a 2.5 175 EFI Ecu somewhere that is good.
ID:	487708Click image for larger version.
  17. #14
    Jan 2020
    Pinole, Ca
    No more 200 ECUs.
    Still have the 2 A13 ECUs
    Still have the TPS modules
    Have a 175 2.4L ECU
